I already have some USB A to C cables so that is not a problem. I would have preferred USB PD compatibility so I could just use the same cables I use for my phone. I mostly charge my phone using USB C to C and not A to C.
I did not have a Pixel charger to test, but iām guessing something is different that the Apple, Samsung & HTC chargers i tested, which all work fine & charge the lantern.
Were any of those USB-C chargers?
Iād be surprised to find a USB-A charger that didnāt work, and a post or three up is a report that a USB-C to A adapter plus the included USB-A to C charge cable allowed a USB-C charger to provide power to an LT1.
The Samsung charger i tested is for the USB-C S9, but the plug interface on the charger itself is the standard USB A type plug, ( the charge cord supplied by Samsung is the USB-A to USB-C common charging type.
(same as this one: ( EDIT: I canāt get any links to any images to work at the momentā¦ :person_facepalming:
From what Iāve read the solution is to āConnect two pulldown resistors (Rd) with nominal value 5.1kOhm to CC1 and CC2ā inside the LT1 (power sink). Hopefully this can be done for a future production run.
No, if you already adjusted the floor to level 1/150, itās already as low as the firmware can go. The only ways to reduce it more are:
Disconnect some of the bridged solder pads, which could reduce it to about 60% of the default power level. This affects all modes.
I might be able to get the firmware to go even lower, using a new hybrid-PWM trick I found, but it probably would only increase runtime a little bit since the LEDs arenāt the primary component eating power in moon mode. Also not sure yet if itās feasible, but I hope to find out eventually. Itād also have the benefit of increasing the tint ramp resolution in low modes.
Thereās another way to make the brightness lower by speeding up the MCU, but it actually reduces runtime soā¦ I try to avoid that.
Alternately, you may be able to get a much lower level and dramatically longer runtime by using the button LEDs in high mode. Iāve only tried on a prototype with green LEDs, but I find itās easily bright enough to navigate in a dark room. But the orange/amber LEDs used in production might not be bright enough for that.
Wow, there is quite a bit more to that than I was expecting, I guessed it may have been a limit but itās interesting to hear why and see the thought that has gone into this.
The runtime is nice but not the main reason I like moon, the hybrid trick sounds like itās worth exploring. I really like using sunset whilst watching a movie for slight background light with the main lights off. Lower for that would be cool with no worries about runtime.
I have used the Q8 just by the green button quite often to navigate, I will see how the amber works out.
Good points on that, as i did ( and donāt have any) USB C to C type chargers to test, and only tested the more common USB charger devices that have the more common USB-A larger socket port. one fix is to have Sofirn add the 5.1K resistors to the CC terminals if possible, (or at least include the USB-Ato C adapter to work with those chargers that use a USB-C to C cord only. (most people have wall chargers with the standard socket, and for most charging devices like Solar panels, power banks, car adapters, standard wall chargers all still have the type A plug socket as standard anyway.
Please note that the various colors in the preference poll are simulated.
The factory will take the most popular colors and see which ones they can actually make. Once samples are run, images of actual prototypes will be posted.
Yes I know, but they had accsess to the CAD files, and can change colors pretty easily, but also since hes using a standard of some sort, with the numbers and whatever, odds are it will be pretty close, but at the same time, they could be very different, so you have a point.
If we were talking a press run, yeah. The colors and textures would be pretty spot on. The results of this process vary by type or metal, the finish on the metal, the chemical bath used, the dyes used, etc. Sometimes they are spot on, sometimes you look at it, toss it towards a reject bin and scratch it off the list.
I canāt wait to see the actual options either. :partying_face:
