Just received my Wurkkos WK30 in the mail today. I had previously reviewed their WK20 Dive light which I raved about. This one is fantastic as well, but a much different light. Here is a partial description from their Amazon ad:
Multifunctional LED Flashlight,Triple Reflector by 3 Types LED Light Source White/Red/UV Flashlight High 90 CRI with Rechargeable USB Port and Power Indicator Compatible with 18650 21700 26650 Battery
by Wurkkos
Triple Light Source:The flashlight is installed Samsung LH351D 5000K CRI 90,Cree XPEBRD-L1 red beam and LG UV LED. To meet your needs in different environment, besides lighting,especially in detect cash, fluorescent agent, traces of forensic,hunting/animal blood tracking, ID and document verification,pet and pest strains,reading invisible fluorescent inks etc.
Different modes and mode memory:White light source has High(1200lm)/Medium(400lm)/ Low(120lm)/Eco(5lm)/Strobe(1200lm)/SOS(1200lm) modes; red light source has High/Medium/Low modes; UV light has Medium/Low lighting modes. It memorizes the last brightness level used in the general modes (except red and UV beam).
Good battery compatibility and running time: WK30 could compatible with 26650/21700/18650 and able to use 2*CR123A battery in an emergency,the running time could last more than 200 hours in eco mode and about 20 hours in low mode.
Smart design:Direct USB Rechargeable with Power indicator is convenient to use charging and identify the power by the side switch, there will be a special blue brightness reminder in the case of UV group to prevent UV light from illuminating the skin and causing unnecessary damage.
Good Materials: Original LEDs, alum alloy smooth reflector, toughened mineral glass lens with AR coated, thermoelectric separation copper MCPCB and constant current circuit design.
Really happy with this new offering. It’s a functional light as well as a fun light. Despite having 3 emitters, there are no issues with the beams. The LH351D 90CRI 5000K is beautiful. 4 modes of white, 3 of red (up to 200 lumens), and 2 of UV … with strobes on the white and red. When 1st turned on the switch lights up different colors to let you know the battery status. On UV the switch turns on in blue to let u know u are in UV mode. 4 clicks locks out the light. Nice option of cells to run the light. 26650 cell included. Light has a micro USB charge port. IPX-8. Not sure why their name isn’t better known. I find their lights top quality and reasonably priced.
Here are a few pictures. I will be adding more as well as some video in time:
video of the switch. when turning on in UV mode the switch will first light up in green, then change to blue and pulse to let you know you are in UV mode. when one first turns on the light the switch will briefly turn green or red to let you know the status of the battery.
Amazon link: Amazon.com
$32 with Amazon coupon
