I've ordered 1 white B158 (with tracking + insurance) some hours ago. Thanks again for this deal!
Didn't order the brass pill, because I'm not sure if I can make it. I've no idea regarding flashlight DIYs and no experience at all in soldering. I believe I can make it though, since I've done lots of kinds of DIYs (even in electronics), simply following "How to" guides/videos. So... get ready! I'm affraid I might bust your b@ll@cks with what follows... :lol:
ok, that's easy even for me to do! :p
Since it's out of stock, which driver should I buy then?
Supposing I get the answer for Nr.1 or Nr.2 driver, then (as I understand) I have to assemble it with another part (that I don't know) and make it look like FET + 7135 Driver - 17mm - MTN-17DDm ("driver Nr.3" which is out of stock)? But how do I assemble it? I'm not aware of the DIY procedure. I don't even know how are called (and where to get from) the rest of the parts that are necessary for the assembly.
All these words in red... I'm not 100% sure if I understand what they are. If there was terminology with pictures somewhere, it would be really helpfull for a "foreign DIY flashaholic wannabe"!
Anyway, if I understood well the architecture of the pill (which is this), in it's upper part is the MCPBC with the LED emmiter (like this) and in it's bottom part the FET driver with the upper spring (like this). What I don't get, is why thermal adhesive is needed in order to mount the MCPCB to the pill. Where do I have to put the thermal adhesive? By mhanlen's videoI thought that the thermal adhesive (or soldering) is needed if somebody wants to change the LED emitter on a MCPBC. Is it needed because the press fit ring will be destroyed when I'll try to get the original B158's driver out (according to posts #93 to #97), so you propose to put the thermal adhesive instead of soldering (as you wrote @ post #126) ?
Well... at least I understood why I "need the soldering iron to make the connection between the positive and negative wires and thepadson the MCPCB" when I saw mhanlen's video at 0'20" and 2'10" (though I still don't know what pads are). I also understood that "solder theground ringof the driver to thebrass pill" has to do with the "Tutorial for bridging springs" that follows.
[quote=Kloepper Knife Works]
Here's a tutorial on adding a braid (I prefer 18-20ga silicone or Teflon coated wire). "Tutorial for bridging springs":https://budgetlightforum.com/t/-/19507
[/quote]
I've read it and understood the general idea, but I'm not 100% sure if I could do it. As I'm the opposite of an expert in soldering, is there a really easy way to bridge the head/tail spring? Let's suppose that instead of copper braid I'm using an old coper cable (or another cable you propose) that I simply twist it around the spring (from botom to top). Would that be ok, or is it most probable that it'll guide to malfunction?
My concern is what to do... in general! That's why I've asked for a "How to" guide in previous post. Good to know that if I manage to get FET +1 driver with Toykeepers firmware from Mtnelectronics with the driver spring already bypassed that Rufusbduck wrote, then the spring bypass might be needed only at the tail (as shown at the tutorial). So please give me some info where to find something like that (FET + driver and all the parts I need) that can be shipped to Greece. Could the parts needed be on fasttech, dx, gearbest, banggood etc?
Sorry for my confusion and thanks for your patience guys!
Yes you can… I’ll put you on the list… but the codes are now public. Demand has swelled, so you’ll have to be patient about when it ships. Gear Best played it safe with the first order, and in the mean time it had doubled… so they’re placing another order with Brinyte. I’d say out of kindness wait a few days before ordering, so people who signed up early will get the first stock. But there’s no rule saying you have to.
Codes and links are in the first post. Only the colored lights need a code. Make sure you set money to USD because otherwise the code has been giving people problems.
KGB, the A6 driver can also be ordered from BangGood but won’t have the same high quality parts nor can it be ordered with the bypass already done so like me you’ll just have to suck it up and get better at soldering. Get a decent iron and use flux and size the tip and temp for the job. Only experience will make any difference after that. I still suck but I do it anyway.
I surely will, if you give me just a few days. I’ll post my mod video with results and we can go from there. I mean someone else could do it, if they couldn’t wait- but since only 3 of us have lights, and only two are modded… I think it can wait a few days. I tried doing beamshots tonight but it’s terribly foggy… so it doesn’t work well.
Maintaining a mod thread is a fair bit of work as it constantly needs updating to the op or the mods get buried in the thread. Best is to have one or better yet two people who are passionate about it occupy the first two posts so that it can be kept up over time.
Ordered my bits. Thanks for the effort monsieur! It seemed at first that it would be a slow going GB but in the end it heated up pretty quick. Thanks again.
Is it necessary to get the extra pill if you are going to swap out the driver and ledboard?
Are the extra pills being ordered to have the capability for quick swaps to an different LED type/color, or because it’s too hard getting the driver out (and/or causes damage)?
Also the consensus is this is a better alternative to a UF-1503, correct?
So I finally did mine, and it came out kind of easily… I did damage the original driver because it was soldered from the inside. I would say the spare pill is necessary for those people who don’t want to damage the driver and solder the driver from the inside. That ring should make it fairly easy. Soldering the negative to the ring on the inside will make for a flicker free light. I got lucky and mine made good contact by pressing it into place.
