Waiting for the video guide/tutorial, can you please confirm that the XPL HI 16mm you wrote is this? I'd also like to know why you've chosen it instead of this that KKW proposed. Maybe because the one in the first link it's "factory dedomed"?
Got it for A6 driver, thanks for you answer. ΒΤW, I'm sure I suck more than you in soldering, but I totally agree with your "just do it!" point. 8)
Yes that will fit. I ordered a neutral tint. If it’s a 16mm Noctigon XPL HI… It fits. I keep my mods simple, and I haven’t gotten into de-doming LEDs yet. Since dedomed xpg2s are so popular I feel like they probably outthrow the XPL HIs. But you’ll have to ask someone who knows for sure. KKW probably knows the answer.
I’m not a highly skilled modder… I just can make and edit a decent tutorial video. I think user Old Lumens makes some better videos… So I recommend watching some of his videos too.
A dedomed XP-G2 will out-throw an XP-L (Domed, dedomed, or HI) in most situations, but the HI is definitely easier*, and might get you a few more total lumens.
*While the HI is still easier, dedoming is not hard, it just takes a few practice tries to get the hang of it. Many people use gas/chemical dedoming when they are starting out, but I broke more that way than I did with “hot” dedoming.
My method:
Use a hobby/exacto knife to start a small cut at the base of the dome opposite of the bond wires
connect a power source to the led and place on some kind of a small heatsink (you want the phosphors on top to get hot, not damage the led)
run for 20-40 seconds at at least 2 amps
immediately after removing power, use the blade of the exacto to “flip” the dome over, pushing from the side you made the cut towards the side with the bond wires.
I’ve only damaged 1 led out of about 30 doing it this way, and it only takes about a minute.
What ^ said. In order of throw assuming driven hard. In a 1 cell light the line between the domed XP-G2 and dedomed XP-L/XM-L2 is much closer and might flip because of the XP-L and XM-L2 being able to pull more current in a single cell setup. Dedomed the XP-G2 is king for throw in this size lens/power class.
Dedomed XP-G2
XP-G2
Dedomed XP-L/XM-L2
XP-L HI (throw is close to the dedomed option)
XP-L/XM-L2
Reading this topic solves lot's of "don't knows" I have, but also creates new ones! :p
I'm sure I wouldn't like in my first attempt for a modded flashlight to try dedoming the LED, so I'll stick to a dedomed one. It's good news that there are solutions out there, offering "factory dedomed" LEDs (like the XPL HI 16mmmhanlen wrote) or "dedome option" with an extra charge (like the XP-G2 S4 2B on a 16mm NoctigonKKW wrote). What's really confusing for somebody ignorent like me, is that there are a lot of solutions (e.g. here are some for XP-G2 on Noctigon 16mm MCPCB) and... who knows which one to select! :~
BTW, yesterday I tried to find pictures with all the parts of a LED flashlight (that's what I was meaning as "terminology with pictures" @ post #262), in order to understand how a modern LED flashlight is made and the names used to describe all these parts (e.g. pill, spring, tailcap, driver, emmiter, etc-etc). Unfortunately my search was not succesfull. Does anybody have a relative link to share?
Thanks, so what I’m understanding is the ring is “press in fit” instead of the usual threaded/screw in ring, and soldering to the ring only is easier because it’s not thick as the pill itself, so you would solder the driver to the ring first, then press the driver/ring assembly into the pill.
Also it sounds like if I do use the ring it would make future removal/swap of the driver harder, possible trashing the new driver in the process. I do have a butane torch, so I think I’d try tinning the inside of the pill prior to setting the driver in, therefore making it easier to solder bridges for grounding/securing it, and also retain the ability to just de-solder the bridges for driver removal/swap with less chance of damage.
Would someone please explain this, what is “tail focusing”?
The few zoomies I have I believe would be “head focusing” that is the head/lens assembly turns (or slides) in and out while holding the body/tube/tail stationary.
I’ve been wanting a long range thrower for a while, best ones I have now are HD2010, Small Sun zy-T13, and BST (all stock)
With all the reverence for it here I was always curious about (but never got) the Jacob A60. I’m planning on building a UF-1405, and was also looking at the 1503 because of its pocket-able size, but now maybe this B158 instead.
I will probably use a de-domed XPG2 CW, since that is what would offer the longest range, but I’m interested to see what an XPL-HI would do, if I’m correct that would offer a lot more light output in the “unzoomed” state? Since it is a zoomable light then the best of both worlds? So maybe a reason to get extra pills and eventually have both LED types to swap.
A few more questions:
What is the benefit of the red, or green? Why do people want those?
What size MCPCB, 16mm or 20mm?
I understand a 20mm would need reduced in size by 1mm, which shouldn’t be a problem for me, and with the 16mm there would be extra room around it. So either can work, but is there any benefit or disadvantage of one over the other?
Basically yes to everything here. I just press fitted the driver inside of the ring, which was still inside the pill after tapping out the driver. I should have the video done sometime tomorrow, and it will all be pretty clear.
is anyone going to make a video showing the difference between the stock light and the modded stuff you folks are talking about?
I am curious to see the results.
Hmmm, not sure why I can’t visualize the difference on this. Twist the body and hold the head, or hold the head and twist the body? works either way doesn’t it?.
I have a few small zoomies, An Aleto 18650 (Zeusray EDC100/Sipik SK73 clone), a SK-68 and a Trustfire Z8, the first two are “slide” to zoom and the Z8 is threaded so you twist to zoom. On all of them the LED is mounted in the body tube.
It seems to work either way on all of them, in other words you can either hold the body/tube/tail and twist/slide the head, or you can hold the head and twist/slide the body, does the same thing.
By the way, I’m planning a couple of special 360+kcd lights. I’ll post them for sale after the order comes in and I get them modified. Build details will unfortunately have to be a secret between me and the people that buy them. I hate being mysterious, but I have to be.
