Hello. Here is my review on BRINYTE ZT40 - ZOOMABLE TACTICAL FLASHLIGHT & Beamshots Comparison Against Convoy Z1 SFT-25R. Thanks for a good place to share content. Please subscribe
The LES looks very small compared to the footprint. Either the emitter is actually an SFT12R, or they somehow have access to a 5050 version of the SFT25R!
EDIT: the LES:footprint ratio is too small for SFT12R. So the SFT25R does exist in 5050!
Heads up to the LED of the ZT40. Does not look like a Luminus SFT-25R in 5050.
And here are more detailed images of the unknown 5050 LED in comparison to a real SFT-25R.
There are definitely some differences (vias pattern, chip diameter, bonding wires, metal frame).
I dismantled the protected cell which is included with the ZT40. (first version, the newer version for the mass-production lights has a USB-C charging port)
It is a Samsung cell (INR21700-50GB). Max discharge current is around 10 Amps (9.7 A).
It is specified with 4900 mAh.
The protection circuit is equipped with 3 STF8233 MOSFETs (each with a source-drain current of max. 11 A).
(Made a new post for easier linking)
The second variant of the Brinyte battery (with USB-C charging function, which is shipped with the mass-production lights) uses an LG INR51700M50LT cell. This is specified with 5000 mAh. The battery is about 76.3 mm long with protective circuit and will therefore not fit into some lamps.
There are 3x MXN2384 MOSFETs on the circuit board for the protection circuit, each with a maximum drain-source-continous current of 9.5 A.
The charge controller is a LowpowerSemi LP28303A. It can be supplied with 4.5-5.5 V and delivers a maximum charging current of 2.5 A.
