Please be nice - first attempt at a mod post, all constructive criticism taken on-board :) I recently changed out the stock 5-mode driver in a UF C8 with a KD 8*7135 driver, which I promptly butchered whilst trying to solder the mode-pads... Once I had managed to re-attach the ?input resistor to the board after melting it off, & the LED output lead to one of the 7135 legs after destroying the output lead solder-pad, I was back in business....albeit with a draw of 2.4 amps at the tail :( My aim was to increase the throw by de-doming the XML - this is what happened; The sacrificial goat C8 in question;
With dome;
Without dome;
yuck - I guess it was a rather messy shave job... I decided to drill the reflector base out to 13mm, & lower it slightly by putting a thinner white insulator disc;
I'm not too sure what difference that made, but it is a difference ?!?! Going by the beamshots, I don't think much was achieved - probably took a step back in fact.
I'll probably replace the XML with an XR-E soon, & compare the difference, after taking some night distance shots. The shots above were about 1.5m away.
Thanks for laughing reading.
- ps. - check out my for-sale thread for a slightly used C8.... ;)
You de-domed by slicing the dome off with a blade, leaving a thin layer of ‘dome’ on the die?
You could try melting off any dome that remains with gasoline / petrol. Drop led in glass of fuel, cover, come back around 24hr later, several people say it works great.
If you sliced the dome already, it might only need a few hours. I did one I sliced first and it fell off after just three hours or so.
I just wiped off the star and didn’t touch the emitter at all. I let it dry for a bit and that’s it. Others may clean with something else.
There's some guys using LED Seal, but I think you lose a little output from it, and there are other guys that posted they've used a de-domed light for one year and no problems at all. More info here: https://budgetlightforum.com/t/-/17374. Some say the small, frail wires are gold, so they won't oxidize or anything, and the emitter seems to have a coating on it anyway.
For me, when I get a chance to do a couple of more de-domes, I'll use the gas soak method (24 hrs+), verify all the silcone is off the LED, pour some isopropyl alcohol over it to remove gas residues, and leave as is -- that's the plan anyway. It seems to be the best, easiest way to go.
I’ve done one that way, so for me it’s 100% success
This seems to be the most successful way to do it. The key is adequate time. If you do not wait long enough, you may break the bond wires. The dome will basically fall off, so you should not have to do anything other than maybe gently shake the dunked emitter to see if the dome will fall off.
Well, if you saw my thread, I'm 1 for 1 using gas, and my other methods, batting 0% . The only thing guaranteed is death and taxes .
It just seems the most reliable, accept for those with special talents and setups for heat methods. Some guys also had successful acetone de-dedomes, all I know is gas seems to be the easiest and seems to be reliable, and appears to be the latest recommended method from several people.
From my failed acetone method, I believe relic38 or dthrckt (?) mentioned if there's still hard silicon or any silicon left covering the emitter, re-soak it for a while. If I were to try acetone again, that's what I'd do - re-soaking until it falls off or comes off easy.
Yep, I sliced it with a thin razor, but it was a little more resistant than I expected, so I had several hacks at it, & it looks quite uneven through a magnifier.
I might take it into work today & dunk it in some solvent for a while.
The solvent (75% naptha) didn’t really ‘melt’ it, rather made it crumble off, unfortunately taking off one of the connecting legs in the process… Good news is that it still works, but seems to pull slightly less current ~2.19 amps.
It seems to have cleaned things up a little, the lens is off-center though.
So I just wanted to ask if others think it is worth it to de-dome an XM-L T6 in a C8 or not. I have one and was thinking about doing it. I also have a Jacob A60 on the way so I am wondering if de-doming the C8 will give me a beam like the A60? If so, then I don’t see a reason to de-dome the C8. It has a nice hotspot as it is, but I would possibly like more throw. I was thinking about doing it and ordering an XM-L2 U2 or something to swap in anyways. So if I ended up not liking it, I could just swap any ways. I also have a UF WF-501B with a T6 that I could de-dome as well as 2 UF SK68’s and 2 SK98’s (one with an XM-L T6 and another with a XM-L U2-or U3). Would it be worth it to de-dome an SK68 or possibly an SK98? From my understanding de-doming a led in the SK68/98 will give me less flood but more throw, right? Thank you for any and all help. I’ve been trying to read up and see what the difference is and if it is worth it. I haven’t been to successful, otherwise I probably wouldn’t be posting asking lol.
Here's a comparison of a dome-intact P60 and a de-domed C8. That's the closest I can get, I don't have a C8 with a non-dedomed LED right now.
P60 was at 2.8A, C8 at 3.2A. C8 using the XR-E reflector (with the wide flat area around the emitter hole), it throws better than the C8 XM-L reflectors.
I completed and tested a C8 pill last night - Nanjg @4.2A (12 x 350 7135's), measured 4.40A on a Samsung 20Q, de-domed XM-L2 U2 1A from IOS. Without any attempt at focusing the emitter and using the stock lens, measured 102 kcd, taken at 5 meters. So, this C8 can really throw, and compared the beam to a stock A60 and it's definitely a bigger hotspot, and of course has a lot more light in the spill. With aspherics, specially these plastic lens, you lose a lot of lumens compared to a reflector light, but you should see an advantage with de-doming them for throw. Note, you lose approx. 15-20% of lumens and can double your kcd when de-doming. That C8 pill I did would probably be about 45-50 kcd if not de-domed. de-doming doesn't reduce the flood area, just lessens the brightness of the flood area from what I've seen in reflector lights, think same is true for aspherics.
I would say give it a go if you’re after an improvement in throw. I’d also recommend it if you dislike the tint for being far too cool/blue and want better contrast and definition when scanning distant vegetated areas (because of the extra green light).
As you can see from those great beamshots, a full gas dedome usually does some predictable things to the tint.
1. It warms the colour temperature quite a bit, I think I’ve seen figures of around –1000k which feels about right to me, could be more even.
2. It pushes the tint considerably towards the green side of the chromaticity scale.
3. It removes basically all of the famous XM-L chromaticity variation between spot and spill. A big benefit that I like a lot, also makes the new tint more acceptable to my eye since whatever it ends up being it’s the same right across the beam profile.
With that in mind my best results in terms of dedoming have been with the coolest/highest output bins and in particular tint bins that are more on the purple rather than the greenish side of the chromaticity diagram. For XM-Ls that would be a u2/u3 in the 0-1 and A/D tint range.
Anything that is already more green to start with will just become far more so afterwards, maybe to an extreme extent.
Wonder what those really green U3-2S tints would look like dedomed!!
I haven’t dedomed any XML2s but I’d imagine the same rules would apply.
In terms of success rate with the straight gas method, I’ve done 3 and all have been a complete success. Would highly recommend this method over anything else.
