Cheap UV Flashlight to detect/test sunglasses UV protection
Hi guys. As title says, any cheap UV Flashlight to detect/test sunglasses UV protection if that is even possible? Any AAA/AA format will do and runtime is absolutely not of any importance nor is throw or multi mode or anything fancy. As long as it is cheap, turns on and off :smiley: and will fill the above requirement, I’m fine :slight_smile:
I just want to make sure that the sunglasses I will be purchasing will be effective in blocking UV.
best is use one of these, costs next to nothing:
It has a load more power than a led, it has a wavelength range from 300-400nm, so it gives more information than just for one wavelength, with copier paper (=bleached, so will fluorescence) behind the glasses you can check if any significant uv is transmitted.
I see. But its still a bit pricey for basically a very limited use. I do hope other members have different options :slight_smile: Thanks though.
Seriously, I think any optometrist these days will have a calibrated UV source.
If not, think twice — then find an opthalmologist.
My eye doctor’s shop uses a UV device calibrated to verify UV is properly blocked.
That’s because people making lenses and coatings do screw up from time to time.
Seems quite cheap too me, when compared to possible eye damage from wearing sunglasses that you don’t know if they offer uv protection or not
Curious too if their is anything more torch like available,
the strip light above seems fine, but something easier/smaller to shine through sunglasses lenses would be better ?
If you want to check for deep UV around 200nm just look at a HID street lamp out of the edge of the lens. Polycarbonate or Lexan safety lens defract the UV quite a bit. There will be a red fringe on one side of the light a blue fringe on the other side of the light. This is the near UV around 400nm that LED lights put out. There will then be a gap the same size of the light and an additional stripe of blue this the far UV around 200nm.
how do you test sunglasses with a UV flashlight?
You put on the sunglasses & shine the light in your eyes. If you go blind, bad sunglasses!!
:beer:
I had gone through the posts. I think, These kinds of products are also available at online for a reasonable price.
Safety Spectacles
I had no idea that datpiff views were being sold. I guess datpiff is a bigger deal than I realized. (go ahead and mark the quoted comment as SPAM)
I don’t know if it’s been mentioned before but I’ve just had a delivery from FastTech, a AA, 3 mode zoomie @365nm, what the hell they thought you need modes for - high-low-strobe - on a UV light. It fluoresces everything it should so there’s 365nm in there somewhere along with visible light. Excellent for the price. 8)
UltraFire 1*LED 100LM 3-Mode Purple Light Zooming LED Flashlight $5.68, also available with yellow, green or blue LED apparently. :slight_smile:
Not bad on the throw end but weak at the flood.
High, low but really? Strobe? Too lazy to change the driver? I wonder how much loss through the lens this has?
I know you have the KD P60 from the other thread, got a comparison?
Just eyeballing them, the KD P60 is about the same using 1x18650, and the Ultrafire on AA, I contacted FastTech to see if the product description was right giving the operating voltage as 1.2v-3.6v they said yes and confirmed a 14500 could be used without blowing the LED.
With the 14500 and the lens on spread the KD P60 wins but with the lens set for throw it gives a much more concentrated beam than the KD P60. The LED Looks like it’s encapsulated in a bullet shape that protrudes into the reflector when zoomed in for spread but falls back when zoomed out for throw.
For $5.36 (plus the 14500 if you don’t have one) it’s a bargain.
It’s won me. I can use the strobing UV in a night club …
I’ve been very impressed by it on high and zoomed out to throw.
Does it project a focused image of the die?
I do know you can check for polarization by taking two sunglasses lenses one in front of the other and hold up to a light source and rotating one 90 degrees , the light transmission thru both lenses should completely go away and you will have a black view thru both lenses
UV protection…not sure on that one
For UV protection check, go to any good eye doctor or optometrist and ask them (don’t trust the cheap chains, they’ll lie to you to sell you new lenses)
A good eyeglasses shop always has a calibrated UV source and they check the lenses when they come back from the place that makes them and applies the UV coating, to make sure it’s applied without any thin spots or missing areas.
Yes but blurry, not as sharp definition as some other zoomies, you can see the square shape but not at all clearly. If it zoomed out further it might be more defined, the front end only moves 6-8mm.
Does it really seem to be 365nm? Should have very little to no purple glow with 365nm.
