GB closed,as well as this Giveaway.
BLF SD10 will be sent freely when samples confirmed.
I will PM winners asking your address.
231 posts, Winners are: 76# 155#.
Congrats. PM will be sent. M4D M4X Cereal_killer
Thanks Lumintop for supporting this Giveaway.
They're really helpful with this group buy,they did a lot to make this GB happen.
SD10 special BLF version. (a 4th custom light by Rey)
Price is 39$, (market price is usually 59$)
Read the original post here.
Tentative spec is:
Good UI:(like the Olight Baton’s )
From Off:
-0.5s press to moon
-Quick click to last mode used
-Double click to Turbo (or highest mode)
From On:
-Quick click to Off
-Press and hold to cycle through modes. (1/2 second pause at each mode). Release to select mode.
-Double click to beacon
3A at high, 0.8lm at moon,XML2, nw and cw available,3C tint.
0.8-4.5V driver voltage. 3K HZ PWM.
Double-sided AR coated lens,OP reflector.
Reverse polarity protection
O ring, wrist lanyard, aluminium AA carrier, all included.
This giveaway is courtesy of Lumintop, 2pcs BLF SD10. (if GB succeed)
GIVE AWAY RULES.
1.Like Lumintop's facebook page.
2.Winner selected by Random.org.
3.Your post # here is your lucky number.
4.One entry per person per day.
You can also comment anything in the Group Buy, there are 2 chances as well.
