Hello peoples! Last night I finished a project I was putting together for some time. Working on parts of it as they came in the mail.
First, lets start with the subject of this mod, the HP1, that I bought on Amazon for 9.99 with free shipping (for orders over $35):
The light is very solid and well built. Anodizing is good, and the threads operate fairly smoothly. But even on a 14500, there’s one thing it can definitely be. Brighter. However, that’s not going to happen much with the XP-E that was in it.
Taking the head apart, we can see Coast’s pillar design, with the led mounted on top. This light did have threadlock around the pill, but I managed to break it by holding the light in one hand, clamping pliers down on the pillar in the other, and twisting.
I will not be using this design, so it has to go.
There we go, much better. I also drilled a hold in the middle part for wires to go through, but forgot to take a picture of that.
So for this, I needed a GOOD 20mm heatsink. I didn’t want to screw around with melting solder, and having a hollow piece of copper tubing, or anything like that. So after searching on ebay, I managed to find this:
1 x 8oz Solid Copper Bullion Rod Half 1/2 Pound lb Shell Round Bar
And oh yes, it’s heavy.
After much work with a hacksaw and my drill (snapped the cheap drillbit, but still used it to finish), I now have my heatsink. For anyone wanting to make one of these into a triple, I made the heatsink about 11mm thick. I would recommend 12mm, as I had to get creative with getting everything fitting tight as I will mention later.
I also bought some 0.2 x 100 x 500 mm copper sheet, and cut 2 strips to each go around the heatsink. When you “zoom” the light over the strips, it holds it snug, and will be like so:
Now that this is done, I can start installing my LED and driver. For the driver, I used the 15mm 5x7135 driver from Mountain Electronics. I had him add 5 additional 7135 chips, and flash the Star Off-Time firmware. Output is Moonlight - 2% - 25% - 100%
For the LED, I had to go with a triple. I didn’t have an EDC triple flashlight, so it had to be done. For fun, I decided to use 3 of the cool-white Samsung LEDs, and I reflowed them onto a Noctigon triple star, with the Carlco optics. The LEDs are 1.28 each shipped on ebay.
Ebay link for LEDs for those unfamiliar:
I used Arctic Silver to attach the LED star to the heatsink, and then to attach the heatsink to the stock heatsink that I cut down. I now have a pretty clean, complete module.
After I screwed it back into the body, I put the strips of copper sheet around the heatsink, coated the outside of the sheets with Arctic silver, and pulled the flashlight head up over it. Forever bonded as far as I’m concerned.
The lens I used fit very well. It is a 20.8mm x 1.0mm Water White AR Coating Glass from Kaidomain.
I mentioned earlier that I made the heatsink a touch too short, even at the thick 11mm it is. So to make sure everything is held tight, I cut 2 20mm circles from a screen protector I had, and stuck them both to the Carlco optics. Problem solved. Do keep in mind, that in the head of this light, it is not designed to have the standard method of o-ring, and then lens. There really isn’t room for an o-ring before the lens, unless you have a very slim o-ring, which I did not.
Nevertheless, I am very happy with the results, and to see my project a success. Shot of the business end:
It settles at around 3.2A at the tailcap on high from a fresh red Efest 14500.
Thanks for checking it out, and for all the help you guys have given. If it weren’t for digging through the forums, looking at build threads and everything, I wouldn’t have been able to complete this.
——Update 6/10/2015——
Took some beamshots at the nearby bike trail tonight.
Control shot (Trees are probably 25-30 yards):
Moonlight (pointed at ground):
Low (pointed down, little farther up):
Medium (between ground and trees):
High:
For comparison, my BLF SE X6 with de-domed XM-L2 U4 1C. It’s actually only running at less than 3A since the driver is un-modded (for now):
Another of the BLF SE X6 much further away:
Control:
High:
