It depends on several factors, like the ambient temperature, wind speed, how you’re holding the light, the type and state of the battery, etc. The short answer is: It can get very hot, so you should allow the turbo step-down to do its job and also manually turn down the power if it gets too hot. Unless you want it to melt itself. If that’s what you want, you could wrap it in a blanket on turbo and it’d probably start a fire. Maybe even explode. Great fun for the whole family.
This light will not keep you from shooting yourself in the foot.
I really did think of that Chuck, and decided against gifting one. The friend I had in mind is just reckless, and will need something with less power. I don’t want to have to worry about anything bad happening.
Rey’s Ti clip looks like it should fit, but the included screws aren’t going to help. You’ll need your own screws and something on the other side to hold them.
I can fit the clip onto mine and the holes appear to line up closely enough, but the clip is a bit short for this light and it will interfere with unscrewing the tailcap.
[quote=DB Custom]
I used the A6 5A last night and in real world use outdoors the tint made less difference to me than I would have thought. I found myself in mode 4 or 5, searching for an item in our shed and spotting a bolt stuck in a flat tire, plenty bright in use and the tint was really of no consequence.
Dale, do you see ‘rosy’ at all in the tint? Don’t like rosy here, at all. Guess I ordered the wrong one.
THANK YOU to all who commented on the tailcap spring mod. I watched some threads in the Forum on it last night.
(I will just play with my Olight M3XS UT that arrives today!)
So strange, my XPG 5A is pretty rosy, not at all yellow…maybe this is the unknown between 5A1 through 5A4 at work… I wonder how varied the tint range is? Your picture did look pretty yellow and frankly a pretty nice color to me, can’t wait to get mine!
Try it in the fog if you get another, those yellowish tints are awesome if you are out early or late in the fog, or just in rain, they tend to cut through it while brighter/whiter lights reflect back in your face and reduce visibility.
Maybe we need a “General Public” warning. This light is not for “General Public” use, anyone who is irresponsible, drunk, likes to turn on lithium powered lights and leave them, children, older people with memory problems or circulatory problems, all can cause problems with this light and the D80. ALL high A drivers can cause burns if you leave them on without heatsinking them to your hand for a significant time and then pick them up.
This all varies by ambient temperature of course: I tested my new BLF D80 with a Samsung 25R, it runs turbo mode at about 4.3A according to my crappy DMM at 74 degree ambient temperature it got hot enough in constant turbo to be somewhat painful, so that I would have to move hand contact around a bit. I tested it the next night continuous running at about 67 degrees and making more hand contact with the head, and its nice and toasty only. YOU have to be smart with these lights running high A, you are the “driver” and you can use the tool to run onto the sidewalk and run into people (or start a fire), or you can keep the car on the road and stop when the traffic light is red (and use the flashlight like a flashlight, and turn it down if it gets too hot for you)…
Hand contact is HUGE. You are a massive water cooled circulatory heatsink! If you keep your hand on the light, the D80 should not get hotter than uncomfortable under normal circumstances, the A6 should not either if you don’t keep hitting turbo over and over and let the timer time out turbo. The only small light I have not been able to successfully heat sink constant turbo (without burning myself) is my XPL triple at 6A, I haven’t gotten my A6 yet, but if you are smart about it and aren’t really heat sensitive, I bet you could deal with a constant turbo on this until the battery drains enough for it not to matter. Or, you could set it on a table and keep hitting turbo till something burns out or it starts a fire if you wanted to be destructive…
