Oh come on, don’t be a drama queen here, it is completely illogical to declare “malicious intent” with this. Its a Chinese company trying to make a profit, probably some lazy/shortcutting employees causing issues here, they certainly didn’t sit down and say “ooh, let’s try to destroy this light or cause harm to David”
I completely understand being unsatisfied with them, I haven’t gotten mine yet and I’m not jumping on any bandwagons. But malicious? We all know those flashlight companies are out to get us!
no sure they didnt sit there and said lets screw up the threats of this light make it not fit with any other
but i have a manker light this soldering done on the driver dont look like manker so maybe one the way from banggood to the final factory there came a factory and said we can do this tube faster cheaper better but they didnt had the right tool to cut the previous sampled threads….
the threads can cut by tools which are quiet costly or can be done on the lathe which also have to have to right set as a metric or not and tools can be new (tight) or used (loose fit).
manker is in guangzhou so is banggood so would be interesting someone from bbg ever go to the factory and check ?? maybe we could get pics.
one thing is quiet clear we all know the chinese can make very very good qulity flash lights so its not that they dont know whats going on on the market.
My Manker A6 is 100% right out of the box.
Great UI - Thanks TK and Wight et al.
The 1A tint looks fine to me.
EE may have had better CQ but I’m very happy with what I got.
Thanks for the GB.
I doubt that these lights were produced one at a time with the threads hand fitted, which is the old artisan method that lead to non interchangeable parts. If you are going to make 1000 tubes and then make 1000 heads and 1000 tail caps and then put them together into 1000 lights you need to have a spec or a print for each piece and build them to that print. The print should call out all the important dimensions, ID OD length, thread diameter, thread pitch etc. If someone made 1000 body tubes with a thread pitch different than the spec then none of the heads or tail caps would fit.
Maybe that’s what happened, the body tubes were cut wrong and they found the problem before all the tail caps were machined and they changes the thread spec to make it work, or maybe they they changed the print before they started production. I don’t know if it was a simple mistake, poor quality control, or intensional change so that the parts won’t fit together with the EE A6’s.
No mater how it happened I’m disappointed, I thought I was buying a light was was the same as the production A6 I have but with a really good driver a better MCPCB and a slight machining change to allow for a clip. What they made don’t match the production A6 so now I have parts that look the same on the outside but have threads that don’t match, I can’t just swap my spring bypassed X6 tail cap over to see what difference in output is. I can’t just put my triple head on the new tube to go to get the deep carry clip for my EDC light.
I was thinking about getting in on the X6 v2 group buy, partly I was waiting to see how the quality of these turned out. I was also excited to get short tubes, and extend tubes but I’m not going to be buying them from Manker now either.
I will be taking one of mine apart tonight to measure to make sure that spacer I made for the EE A6 fits, if is does I’ll be sending stock off to the machine shop on Monday.
I am still hoping the “out of stock” delay is due to an agonizing reappraisal and correction at the production end.
Fix it, orphan the early thread as incompatible with anything, make a big run with the specified thread that legos — and I’ll buy three or four more made to that spec.
Then my three original unique-thread lights will become unique collectors’ items, like postage stamps with the airplane upside down.
I can’t get the tail cap retaining rings off the 2 lights I have. I know they turn in the usual direction (left to loosen) but neither want to turn.
Normally I can get retaining rings off using small screwdrivers, needle nose pliers, etc but these seem to be on really really tight.
Anyone else having this problem?
Other impressions after playing with the lights
Positives:
I really like the 5A tint (my other one is a 3D).
With a fresh off the charger Sanyo 18650FM I’m getting 4.5A’s even without bypassing the springs.
The interface is great!
Negatives:
Can’t get the tail cap retaining rings off.
One of the heads won’t come off.
Pin size chips in the thread anodizing.
Anodizing missing in other small spots on the corners of the head
Clip hurts my hand :_(
Not a bad light and I don’t regret getting the 2 I got. Functionally it doesn’t do anything else my Convoy S series lights do (light up the night and easy to carry around). But it’s like guns…one can never have too many even though they are the essentially the same
The most likely answer is that Shenzhen Jim of EE complained and raised issues prior to his post here so the threads were changed so it wasn’t an exact copy of the EE A6 and so that we could not Lego parts. Simple fact is that it doesn’t meet specs as requested by those involved in this amazing GB. Disappointed that it doesn’t Lego but its not the end of the world.
You made me curious, so I compared the lenses of the EE sample and the Manker production unit. What I found is that the EE sample has a stronger AR coating (same as the EE X6), and this causes more green tint shift. The Manker unit has a weaker AR coating, which makes the tint closer to what it should be. This is probably about half of why the Manker tints look better (the other half is because the Manker tints are below the black-body line, 3D instead of 3C).
For me, this is a bonus. I would still prefer a plain piece of glass, but what we got is a lot better than it could have been.
EE on the left, Manker on the right:
Edit: If you’re not sure what’s being shown here, anti-reflective lens coatings make reflections look blue from an angle. They also send a blue halo out the front of the light at the edge of the beam. Selectively bending some shades of light like this allows more total lumens to come out, but also acts a bit like a prism. The outer edge of the beam becomes more blue, while the middle becomes more green or yellow. Plain uncoated glass gives a more pure tint, but at the cost of slightly fewer lumens. I prefer plain over AR-coated, because I can see a tint shift much more easily than I can see a slight change in brightness.
I don’t know, but I think it was probably something like that. Most of the focus had been on making sure the driver was good, so maybe they thought the host details weren’t very important. But in reality, the host was assumed to be a solved problem so the focus was on the new parts like driver, firmware, and tints. I’m hoping that future efforts will include someone who speaks both languages well to better communicate the subtleties and ensure nothing is misunderstood.
