Hey guys, I just made a split-screen thermal video of the BLF A6 on Turbo with a fully charged battery. It was neat, so I put it on youtube here. It’s interesting to see the temperature rise and fall times. I tried something neat at 2m20s just for fun.
You might be able to fix it yourself in just a few minutes without doing any soldering. There have been a few issues with inconsistent milling and one result was the rubber button already partially pressing the switch. To fix this you just need to unscrew the brass retainer, remove the switch, washer, and rubber button cover. Then evert the cover and slice half a mm or so from the rubber cylinder that actuates the switch and reassemble. If you don’t have needle nose pliers you can bend a piece of wire into a u-shape and twist that with regular pliers to remove/re tighten the brass retaining ring.
If I may “hijack”, as I am a newbie as well: what are “bypassed springs”? the copper s2+ spacer is for heat dissipation? Triple notcigon means there are 3-LED’s? and what does “narrow Carlco” mean (appears to be a brand)…and if so, how do you determine what size?
Thanks in advance and sorry for the seemingly silly questions. Looked around but found more info about people selling, as opposed to what they actually do.
No worries, and not silly. Much easier to go to this thread to see what it is and how it is done (too many posts here to find it)
The purpose is to lower resistance caused by the spring by soldering a wires from the top to bottom of the spring. Also since less current actually runs through the spring the spring tends to last longer.
Received mine today, must been from the 2nd or a later batch as had to wait but was worth it. Quality looks really good, anodizing very even, clip is good. Only quibble is that the tail cap spring seems a bit flimsy as has been noted by others but works perfectly. Waiting for 18350’s to try in shorty tube.
After ordering mine in September, and having he first one get “lost in the post”, my unit (5A tint.) has left NY, and is en-route to me via USPS. Fingers crossed it makes it here and I can’t wait to try this unit!
Any comments, advice, guidance?
Oh, and kudos to the Banggood folks for replacing the unit after agreeing it was lost in the post. I had t wait a week th first time I contacted them to “see if it showed up”, but eventually they traced it, and did the right thing. Good job Bangood for h support. Bummer it was lost in the international post the first time, but hey, not their fault.
Spring bypass, is to use wire to connect the part of the spring that touches the cell to the board for lower resistance.
The copper spacer is to fill in the extra space the triple MCPCB and the Carlco optic leave in the head instead of the single LED board and reflector. 3 LED’s instead of one, not quite 3 times the light, also almost 3 times the heat, and 3 times the current draw from the cell. Plus extra fire hazard.
The mod is a 3-emitter Noctogon brand 20 mm copper mcpcb that fits Carclo 20mm triple led optics in this case the narrow beam version. The spacer is needed because the triple optic is shorter than the stock reflector so a copper or aluminum spacer is used under the Noctogon to raise the board and optic up to the lens. The correct spacer has a hole in the center to match the hole in the Noctogon.
Hi guys, I got one anodized and one non-anodized light home just recently and the non-anodized light works great, no problems whatsoever. But the anodized light worked for about 5 minutes before pressing on the switch just wouldn’t do anything, and after a tail switch lockout to turn the light off, it won’t turn on again.
Having looked around on here, it seems as if I should open up and switch out my switch, but I’m not sure. Does anyone have any thoughts on what I should do?
Tighten the brass rings in both ends. Needle nose pliers, a small pair of scissors, or a 1” section from a large paper clip bent into a U held in regular pliers or vise grips. To check the switch itself remove the tail cap and short B- to the bare end of the battery tube and it should light. If after you’ve tightened both retainers it still doesn’t work check to see if the gap between the battery tube and pill section is the same on both lights(should be just a hairline space). If the ano version has a larger gap this might be an indication the retainer can’t screw in far enough. The ano version depends on the bare metal surfaces making contact to carry current through the light. On one light I found the threading for the driver retainer didn’t go far enough to press the driver and caused a similar issue. Fixable if you can solder spacers on the driver or make a 17mm ring to place between the retainer and the driver.
