Just received my Wurkkos TS10 cool white, black anodizing with ice blue aux leds.
Here are my preliminary impressions of the TS10, with comments comparing to the FWAA:
- Build quality - excellent. No issues, but I just got the light so haven’t had time to really test. The light feels solid and well built.
- Hand feel (how comfortable and secure the light feels in the hand) - poor. The TS10 is even more slippery than an FWAA. No knurling, but the light has a few ridges which help a little. It feels enormously less secure in the hand than lights with more knurling like the Sofirn SP10 or Eagtac D25A. It’s good enough but there is always a bit of feeling that it could squirt out of the hand. It’s ok, but I’d probably have liked the body design a bit more if there was some knurling or more aggressive ridges on the head and tail. Also, the gentle fluting of the body tube to the tailcap does not produce as secure a hold for a cigar grip compared to the FWAA.
- Body shape - the FWAA follows the same body shape as the FW3A: A small tail with sharp indent to the body, then a gradual flute out to a longer head. This makes it easy to tell the head from the tail by feel. In contrast, the head and tail of the TS10 are closer in size and the concave body tube doesn’t tell you by feel which end of the light you’re holding. I suspect it will be much easier to grab the light in a pocket and accidentally push on the head rather than the button compared to the FWAA. The FWAA’s body shape is more intuitive and superior in this respect.
- Size - phenomenal. The TS10 thing is tiny! Compared to the FWAA, the TS10 is approximately 1mm wider and 3mm shorter (72mm long compared to 75mm). The TS10 is smaller than the FWAA and one of the smallest 14500 sized lights around.
- Beam - phenomenal. Either owing to the choice of emitters or optic, the beam is significantly more focused than an FWAA. This is still a floody light, but the beam shape feels more like that on an FW3A than an FWAA. The optic appears to be different than an FWAA even though the diameter of the optic looks about the same. In terms of tint and CRI this is also probably the best “cool white” light I’ve ever seen. Previous reports of 5500K and 99 CRI sound about right.
- Output - excellent. Despite its overall lower lumens than an FWAA, the more focused beam keeps the TS10’s hotspot looking quite bright. That said, in a rough ceiling bounce test I do think my FWAAs with 4000K 95-CRI SST20s are noticeably brighter. Figure maybe 1400 lumens out-the-front for the FWAA compared to 1000 lumens for the TS10.
- Features - excellent. Anduril 2 with aux leds in a ridiculously tiny package. What’s not to like.
- Switch - very good. The switch is noticeably crisper and requires more pressure to activate than an FWAA’s switch. It’s even better than an FWAA’s switch with o-ring mod. It really feels like Wurrkos put some effort into getting the switch just right before releasing this light. This is still a light with a tailcap electronic switch…. accidental pocket activation is still possible unless lockout is used. However, the switch stiff enough and the light is small enough that I would feel comfortable pocket-carrying it without lockout. Personally, I think the TS10’s switch is noticeably better than the FWAA’s.
- Clip - average to below average. I’m not a fan of 2-way clips. Especially like this one where there isn’t enough of a lip to slip the light over a pants pocket without using your other other hand to lift up the edge of the clip. Slip-on clips are also inherently less secure than ring-clips like on the FWAA. Also, there isn’t an option to buy an aftermarket deep-carry clip like with the FWAA. That said, if there ever was a light to stick on a ball cap as an impromptu headlight this is it. The tension in the clip itself is quite good. While being a 2-way clip, this one doesn’t stick out obnoxiously far. I expect the risk of the extra bend getting caught on stuff in a pocket is fairly low.
- Price - excellent. This light is cheaper than an FWAA while having a better set of features.
Other notes:
- It tailstands perfectly
- It accepts both flat-top and button-top 14500s. (I tested mine with flat top and button top Vapcell H10s)
- I did not test for parasitic drain.
- Ice Blue aux leds were too bright for me in high mode, but are fine in low mode. Brightness of the two modes seemed similar to the aux brightness settings of the Emisar D4v2.
- When choosing aux led color, it may be worth considering parasitic drain. For example green aux leds will probably be the brightest followed by ice blue. Red will probably be the dimmest. If you choose red and then find yourself running the aux leds at high power the battery will likely drain faster than if you pick green and run at low power.
My preliminary impression: The TS10 is a fantastic little light. It is better than an FWAA, both overall and in most of its features. The only things the FWAA does better are:
- Selection of stock clips (I might be a bit biased here since my FWAAs are all wearing deep-carry 2-way clips that have been modded to be one-way clips).
- Selection of exotic materials (titanium, copper, etc.). Hopefully Wurrkos will consider making a Ti or Ti-Cu version of this light.
- Selection of color temps. Currently the TS10 is only available in cool white and 4000K neutral white.
- Modability - the FWAA’s star is sized for standard XP sized leds giving it more options for modding than the TS10. The TS10’s tailcap and bezel are threadlocked. That said, some nod was made to modability in the design of the TS10: It has flashing pads on the back of the star for easy reflashing. Also, they used blue threadlocker instead of red, so modders should be able to access the internals.
