Sorry if this has been addressed before, but I have searched the forum as well as the internet and cannot find all the correct info.
Can anyone direct me to a comprehensive thread on Li-Ion battery care. I am looking for things such as; when is the proper time (in term of voltage) to charge 18650, 14500, 10440 and RCR123 cells, both protected and unprotected (if there are differences between the two). I have a decent DMM and all of my cells, including a couple fresh from the package, are currently right around 3.75V. I also have an Olight protected 14500 which was in a light and stopped working. I get a 0V reading from the DMM which is concerning Would this be the protection circuit working to prevent over-discharge or rather a bad cell?
I would love to write something up which could be pinned here for reference, but I obviously lack the proper knowledge to do so. Any help would be appreciated.
Well, thanks for the comments, but it doesn’t appear to be that simple. I was using my Olight protected 14500 in a Xeno E03 and the performance was very much at a “preferred” level when the light shut off and the battery subsequently reads 0.00V. Any suggestions?
Thank you! That is what I was hoping to hear. However, having read about the potential dangers of over-discharge and charging, I was not certain if I should just simply “recharge it”.
Protected cells will show 0V when “empty”, it simply means the chip has cut off the battery from discharging further. Internally, the battery may be at 3.0V or 2.7V depending on the protection chip.
So yes, since you’re using protected cells, just recharge it.
