Phew! 1-3/4 copper round is $100.00 a foot! This project seems fairly reasonable otherwise.
Bucket: bushwhacked:I’d like to see a uhmw disc that would have a copper/brass insert that could fit into an 18650 light and would connect to springs and allow both button and flat top batteries to work. I would use it for solarforce p60 hosts I think with a copper braid/wire direct to the metal disc would improve current and not to mention be unique as far as dropins go. I know there are a few lights with these type of disc’s in to help with recoil. Uhmw is an awesome product.
I'm trying to picture this, but can't quite get there.
Basically just a round piece of uhmw around 2mm thick with a hole in the center( for brass/copper) !{width:100%}http://3.bp.blogspot.com/-jV12S0erDeg/UPxMdpGO5BI/AAAAAAAACDU/XGJmNUgBLAQ/s800/6_RdL_P25.jpg! Would just be a dangled piece of uhmw on the dropin (once soldered to spring) until it was put into a light. Would stop any recoil from making spring bend to the side. I’m on my phone at work so I can’t really draw up or look for the example but I think it was on a nitecore light. It just wasn’t uhmw. Edit found it
PM me with dimensions. It's trivial to make that if all you want is the disc with a hole in it. I have lots of UHMW lying around.
Awesome. I’ll send some measurements tomorrow.
Ouch! That is pricey indeed.
Copper gets real expensive Bucket. I passed on a foot long 1 3/4’’ awhile ago. It was about $160.00 from memory here.
GB on a foot or two of 1 3/4” round copper :party:
Hmm.
Boring but good for me: copper pill for a SupFire M6 or Smallsun T-08…
Tricky, but potentially awesome: Tail clicky mod for one of the nitecore SENS series (would most likely have to fab a new body tube)
janko.hrasko:how about a copper pill for courui? it really needs some better heatsinking
I’m interested in this as well. Do you have any pictures of the current pill? Rough dimensions?
Linus made some measurements in his thread
it could be a simple circle made of copper pressure mounted with tim or with threads on the outside for even better heat transfer (like stock but a bit thicker and from copper)
Copper pill for the S3 or S6 in order to make it triple xpg2 monster.
New winner! I'm going to make a copper shelf/heat sink 18sixfiftycent.
Second Winner: I'm going to make a UHMW spacer ring for Bushwhacked.
Thanks Bucket, and congratulations 18650.
Congratulations you two. That copper pill will increase the weight (without batteries) of the SRK by almost 50% !! (~150gr.)
And increasing the weight is an awesome feeling in the hand! It’ll be amazing, wait and see…
I didn’t even get to scan and upload my drawings (with precise measures) and you already selected new winner
Next time, when you do a contest please make a plan of contest before you actually do it…
It was spur of the moment. With such an odd looking part he thought it would be fun. The original contest was actually well conceived but the first winner opted out and this was the result.
Thanks. This should be great.
Bucket: janko.hrasko:how about a copper pill for courui? it really needs some better heatsinking
I'm interested in this as well. Do you have any pictures of the current pill? Rough dimensions?
Linus made some measurements in his “thread”:Teardown and Mod Thread of Courui XML2 Aka "Big Head 3x18650 Side-Switch Thrower" it could be a simple circle made of copper pressure mounted with tim or with threads on the outside for even better heat transfer (like stock but a bit thicker and from copper)
I have one of these lights on it's way from China. By the looks of the pictures, I will be offering a copper pill shortly thereafter.
