Oh nice. Simon can you please test the 519A for us? Would love to see the tint on this. Thanks!
I would love to have L8 light with 26650 battery compatible as these batteries easily find and i have plenty.
You can just stick a spacer behind the battery inside the 26800 tube. In that light, even a wad of aluminum foil would work just fine.
Hey Simon will the L8 be available in a host form ? Would love to get one to put a sfh55 in with the 80mm head
S21D is no longer available, was there something wrong with it and had to pull it from the store or did it just sold out that fast?
leave me your address via PM ,i will send one new driver to you
oh ,not suitable
currently no OP reflector for M21F , and there is only 3V XHP50.2 6500K.
i will produce OP reflector for M21F XHP70.2
60 degree ,floody light
the lens is not from carclo .
it’s made by a Chinese company
Spring can be soldered on the spacer board
Where is Convoy S21C? There was A and B, and now D, but no C.
S21C ,triple TIR lens,
The three holes on the MCPCB were too small in diameter for the TIR lens to fit in and I had to send them back to the manufacturer for rework.
Hi Simon will you be adding the new Convoy L8 to your Taobao store?
yes ,
tactical_grizzly: MoreHighCRILumens:Are there any plans for M21F with GT-FC40? I like that size and color.
I’m wondering this as well. I’d be very interested in M21F with either a GT-FC40 or a B35AM.
Does it use the same reflector as M21B and M1? Will there be an orange peel option?
Same for me. I want GT-FC40 or B35AM with USB-C unless Simon can get the new XHP70.3 with 90CRI. That would be sweet!
Is there a convoy usb-c with 12V driver?
M21E with GT FC40 will be available
The holes on the MCPCB were too small in diameter for the TIR lenses to fit in and I had to send them back to the manufacturer for rework.
SKV89: tactical_grizzly: MoreHighCRILumens:Are there any plans for M21F with GT-FC40? I like that size and color.
I’m wondering this as well. I’d be very interested in M21F with either a GT-FC40 or a B35AM. Does it use the same reflector as M21B and M1? Will there be an orange peel option?
Same for me. I want GT-FC40 or B35AM with USB-C unless Simon can get the new XHP70.3 with 90CRI. That would be sweet! Is there a convoy usb-c with 12V driver?
AWESOME!
I want to know how the new Convoy L8 differs from the Convoy L7, apart from using the (very difficult to find) 26800 battery? From the photo on the Convoy flashlight Store on Ali Express, the L8 looks longer than it should be, since it is using only one 26800 cell. Has anyone found any good Group Buy offer for the L8?
the L8 is specs as having a 90mm head size! This is very exciting for me, as that puts it in the same throw range as the Astrolux/Mateminco mf02sV2 and almost the WT90, but with the ease of using and carrying a single cell
That’s a good idea, too, might give that a try while I’m waiting on the P60 springs to arrive. Do you think there’s a possibility of sourcing a stronger triangle-spring for these lights so customers would not have to add parts? Thicker wire might be enough, maybe another coil or two also?
TermsakC:I want to know how the new Convoy L8 differs from the Convoy L7, apart from using the (very difficult to find) 26800 battery? From the photo on the Convoy flashlight Store on Ali Express, the L8 looks longer than it should be, since it is using only one 26800 cell. Has anyone found any good Group Buy offer for the L8?
The convoy store on AliExpress stats the head diameter is 81mm is that correct or is it 90mm?
