Yes, XHP35, just got the new higher Bin cooler temp XHP35’s E2 3C’s yesterday. The LD-2 M2 driver should be here today or tomorrow? Have to machine a JAX X6 ( smooth) reflector O.D, to fit the L6, while I’m waiting on Simon to make the L6 Smooth reflector’s? Take a look at the Acebeam K70, big beam 2000+ Lumens and over 400kcd of throw, whats not to like? I have a K70,Jax X6 and a Lumintop SD75 with the XHP35 in them, they Rock a big tight long beam!!
My 5000k L6 just shipped. Now I have to buy batteries. Those of you who have received your L6 are you using Button tops?
I’m trying to source batteries from the US. Every 26650 on Illumn is flat top. The flat tops still look like they are raised a tiny bit on the positive side, is that enough for them to connect in series? I’m also looking at the 3 5200mAh 26650 options at Mountain. Only one of them is button top and short enough to fit, but it’s unprotected and the recommended cells are protected.
How about using the LD-51, if it would fit? Only requires two cells: http://kaidomain.com/product/details.S025108
I wouldn’t use it, for only a little more than half the out put, 8.4 input 12v (circuit boost ) driver at 1.5 amps…nope. Not in a big light any way? The XHP35 at 4S16+volts and 2.5 amps is way better. ( I think Dale is pushing one to 3amps?) I’m not saying you shouldn’t try it and let the rest of us know what/ how you did and what you think about it? Do some testing and reveal your results, I think that would be cool! :+1:
The one protected 26650 that Richard sells that will fit is the protected KK. It lists as 4000mAh but tests consistently shows it is higher than stated. Closer to 4400mAh if I’m not mistaken and those are good cells. Here
Finally got my order in as well (N4 2A)! I’m in the same boat regarding cell choices (read: not sure which ones to grab).
Possible unprotected contenders I am considering:
Efest purple 26650 4200mAh (67.39mm).
Efest green (older?) 26650 4200mAh (65.11mm).
AWT yellow 4500mAh (67.19mm).
KeepPower Black IMR 4200mAh, PN: UH2642 ver.2015 (67.5mm).
KeepPower IMR 26650 4200mAh, ver.2014 (67mm).
Even thought all of the above are flat-top cells, I am fairly certain the tops extend far enough that stacking isn’t a problem.
I’d love to hear any feedback and/or comparison data on any of the above. It’s looking like the 4200mAh cells are good “all-rounders” but that is just a guess on my part!
KeepPower IMR 26650 4200mAh, ver.2014 (67mm).Even thought all of the above are flat-top cells, I am fairly certain the tops extend far enough that stacking isn’t a problem.
I asked over at r/flashlight on reddit and had Mtn’s unprotected King Kong 4000 mAh recommended, but I have a hard time buying anything in the 4000 mAh range knowing that there are 5200 mAh out there. That’s 25% more capacity! Is Simon recommending protected cells because the driver lacks protection or just because of the LiIon 101 danger warning about discharging cells in series?
What cells are recommended?
Can someone recommend cell which is protected and ships to EU? from Fasttech, gearbest or banggood? And of course no longer than 70mm to fit. Are the Thorfire 5200mAh 26650 batteries enough for this light?
Maybe that smaller capacity keeppower batteries, they seems to be 69,6mm 26650 keeppower 4500mah haben wiederaufladbare Li-Ionsbatterie geschützt Sale - Banggood Deutschland sold out-arrival notice-arrival notice
Have you read this tread ? there is some good info on those Thorfire 5200mAh 26650 batteries :
I received the above today in one of Thorfires famous “happy” boxes, very well packaged. Yet again struggling to upload images. Anyway they arrived with one cell at 3.67v (fine) & one cell at 3.91v (higher than I would expect as normally lions would arrive showing between 3.60v- 3.80v ?). Official specs for the cell from Thorfire are 5000mah Continuous discharge rating 10 amp Protected INR Cells weighed 95g each Flat top (but the positive is raised enough to make contact to run in series…
The new shorter (Ver: 2015) Keeppower 5200mAh 26650 is 69.5mm. However it would be advisable to contact the retailer to confirm which version they are selling!
My L6 came yesterday in bad condition. The AR coated lens has several scratches and the coating was not done good. After cleaning the lens, the coating was total gone. My cleaning of lenses is always the same procedure and I didn`t had any problems with other lenses. Maybe Simon can sell me a new lens, so I didn`t have the trouble with a open ticket on GearBest. Sorry but I´m not able to insert a picture. Can anybody tell me what I have to do, to upload a picture here on BLF?
Robert
Thanks! Maybe I will buy a pair of those.
You have to upload the image to your own webspace or a free image hoster like directupload.net or imgurl and insert the image by linking to it with the “insert image” button. there is no other way.
Btw, sorry for your trouble, doesn´t sound good… the L6 does not come with a spare lens ? Pitty…
K.
Robert
That’s a bummer. If you bought it from Gearbest you need to handle any issues through them. I will mention the glass to Simon though and if he has any extra I will let you know.
Any AR coated lens has to be handled like a pair of glasses or the pricey lens on a camera lens, as applied surface treatments are very prone to damage by cleaning. Some are tougher than others of course and that’s an easy identifier of a quality lens. I have quite a few expensive camera lenses and I have made it a habit over the years to simply not touch them, keep lens covers on, and not get them dirty in the first place. I very seldom clean a camera lens, but if I do have to, I have dedicated lens cleaners and use PecPads designed to clean the sensor so I don’t get scratches.
Sounds like you may not have an authentic Convoy flashlight.
I see Gearbest is keeping up with their high quality standards… :person_facepalming:
Robert
I talked to Simon. He said to contact him directly. I’d message him though the Ali store. If you have any questions just send me a PM.
I also wasn’t very surprised to read the name “GearBest” in this post. I ordered my L6 from BG with the coupon for \$50 - can’t go wrong with that price :)
