Convoy SST40 drivers now coming with R020 sense resistors?
First of all, I am going to say something which is common among humans, and this is to imprint some sort of fearful, bad energy around something in their minds. This bias someone's perception around it, particularly when strong emotions are involved. This is something which must be avoided at all costs… for the light to flow correctly, i.e. to understand and etc.
What I mean with this is that if you are only accustomed to fairly simple unregulated “MOSFET” drivers, it may be harder for you to see this clearly, but it certainly is possible.
These regulated drivers employ a MOSFET to regulate or limit the current, using a sense stage to do this. They are fairly simple too, the only technical difference between a blind MOSFET driver and these regulated ones is the presence of a sense stage. Thanks to this sense stage they can precisely limit the current, and they can do it without PWM (pulse-width modulation).
I somehow sense that you probably feel that limiting the current is bad, but this is not. Without current limiting you could find yourselves with lower than expected output or damaged emitters due to overcurrent. Drivers which properly sense the current can take care of this. The problem I came here to discuss is that these “revised” SST40 drivers are using a coarser sense stage, with more resistance (the R020 versus the older R010), which is undesirable as it unnecessarily drops input voltage.
How did you checked that? :D The voltage difference or voltage drop between the power supply output's voltmeter and the driver's input terminals only appears when the current is flowing. The driver's spring also drops some voltage as it also has some resistance, by the way.
Remember what I said before, by Ohm's law V = I × R. If you use a multimeter and measure the voltage at the driver's input or at the end of the test leads without load, you'll of course get the same value. In these conditions the only current flowing is a veeeery small tiny bit of current which the multimeter needs to get its measurement done, but since it is so tiny the voltage drop in the power supply leads and connectors is also insignificant. However, let the current flow and you'll see. This is the reason I said “hire some assistant for him/her to peek right at the driver with the probes of a multimeter”, this is because when you are connecting the PSU probes to the driver with your hands and you “close the circuit” so current is flowing, you may need someone to put the multimeter probes above the driver ring (negative) and somewhere in the spring. You will then notice a difference: the larger the current flow the larger it will be.
Hmmm, I think the change came when Simon’s supplier fixed the mode reset bug, maybe a component was clashing with the firmware? The drivers had the R010 with the bug and after it was fixed was changed to R020.
At the beginning it was running biscotti and all was perfect until Simon announced his own firmware “12 groups”
The first fixed batch was running at 5.4A and I have 15pcs :frowning: . I also have them in 10pcs S2+ Osram’s Simon sent and the LED turns a slight blue. I’m just going to sell them as is under my 12 month warranty, too much messing around otherwise and it’s difficult to discuss with Simon since 6A is still okay by his view.
Well, the driver I was above speaking about (see #39) has a working memory, but uses the old sense voltage and resistor. I measured ≈1.3A for an R050, but please consider I don't know how good or precise is the sense resistor I used and my reflowing job (and so I can't say 100% sure that the sense voltage in such driver is 65mV). Furthermore, when later I installed an R020 in parallel with the R050 I was expecting to see ≈4.55A maximum (presuming 65mV sense), but it reached ≈4.7A. No worries because an SST-20 can take that, but if you set your emitter theoretically to the brim and actually you get even more current… :facepalm:
Mind you, considering 60mV sense with an R020 and an R050 in parallel the maximum driving current should have been 4.2A.
Tue, 08/24/2021 - 14:46
I received a L21B CSLNM1.TG with what appears to be a 12 group 20mm 6A driver.
Measured 6.5A at the tailcap on 100% with a clamp meter.
Is there an easy way to mod the 6A driver to be limited to 5A so that it doesn’t burn out the CSLNM1 or would be best to install a 12 group 17mm 5A driver?
Is the driver coming with an R020 sense resistor, TimMc?
If so, this means that the driver's sense voltage is V = I × R = 130mV. With this in mind, replacing the onboard R020 resistor neatly with an R025 will limit the current to 5.2A maximum; with an R027 the limit would be 4.815A (4.8̅1̅4̅A), and with an R030, 4.33A (4.3̅A).
Sense resistor standard values extracted from this document at venkel.com.
Yeah, it’s an R020:
Would WFMA2010R0250FEA work?
If the old resistor is a size “2010” (5mmLx2.5mmW), then it would work; that WFM is a really high quality part with high thermal rating, much better than the original.
Guess that's an R025, doesn't it?
What kennybobby said, plus pretty high or highest resistor accuracy. 5.2A is on the limit for a CSLNM1.TG, for my liking. Remember to do a neat reflow job, because if the resistance between the sense resistor pads ends up being a tiny bit lower the current will go up.
I just searched for R025 on mouser and digikey to get that part number. Haven’t ordered from them before. :person_facepalming:
Is there a more appropriate part?
You should first use some calipers or a fine-scaled ruler to measure the Length and Width of the part on the board to determine its dimensional size, then you can find the correct part to order. The resistor value is a separate parameter, but the size must match or it won’t fit to the solder pads.
Then with the size and value known, it will be possible to find a part with a desired tolerance and power rating, etc. Plenty of folks here that will give you some assistance.
I measured the R020 as 5mm by 2.5mm with some plastic callipers.
Yes you are good to go Tim, that is a good part number that you found and will fit and work.
WFM A 2010 R0250 FEA
“WFM A” is the model and construction material code;
the resistor size is “2010” (5mmL x 2.5mmW);
the resistance value is “R0250”, which is 0.0250 Ohms, or 25.0 mOhms;
“FEA” is the tolerance and packaging code.
More than likely I'd personally choose a higher value sense resistor, since I care less for virtually indiscernible gains and more with reliability. O:)
By the way, there are these P5000 and H17A drivers at Kaidomain, regulated variable load drivers too. Asked about them in the Kaidomain thread many days ago. Did someone around here gave 'em ago? They seem to come with R010 sense :THUMBS-UP: resistors.
Thank you for the detailed explanation!
Hi all, here is a pic of the driver I got inside the l21b SFT40, it’s supposed to give 8A.
The biggest resistor seems small, much smaller than the big 2010 pictured in the new “5a” drivers. I’m not sure I’m up to changing it and there was no room to measure it. I’ll measure if I swap LEDs.
I bypassed the tailcap with a 13cm 8ga wire and measured 7.5A at 100% and 3.26A at 50% (group 8). I wanted to use group 8 and swap in a w1 led (green probably) but 3.26 seems underpowered.
Would you be able to make out the part number on the regulator ? it’s the chip south east of the inductor (biggest part).
The sense resistor looks to be 1206, it’s appropriate.
The driver you are using is a switching driver. This means it only takes from the input whatever power it needs to produce its output power, plus the usual additional power which goes into conversion heat inefficiencies which should be quite small in that driver.
Your measurements are thus, well, probably correct; your conclusions, though, are not. The driver is more than likely outputting ≈8A to the emitter in high, and the same I would say (≈4A) for the 50% mode. The reason it pulls even less current in proportion for the 50% mode is because it needs less input power (which is voltage times current) to produce “about half” of the output power (vs high), because of lesser input voltage losses at the driver (less current through the switch, springs and etc. means less voltage drop) and less power conversion efficiency losses (higher driver efficiency).
For switching drivers you need to measure “the real thing”, which is the current at the emitter. This can be done, for example, installing the driver in the pill or body of the flashlight, and then connecting it with extension wires to an external emitter in a heatsink. Then use a clamp meter to measure the flow of current through one of the wires from the driver to the emitter.
P.S: for measurement purposes the external emitter in a heatsink can be whatever type, but better if you don't choose emitters with very high Vf; if you do, buck drivers may not be able to output enough voltage for it (unless you feed them with high enough input voltage, that is).
Thanks for the insights! I was curious about the large coil, I thought it might be a switching driver… I guess we have to speak in terms of power and not stricly current. I will measure again sometime this week with a p42 molicel for which I have the datasheet. Also, aren’t some switching drivers actually more efficient closer to the higher power limits?
So would you approve a simple LED mcpcb swap to properly drive a cslmn1 (w1)? 4A is about right for w1… Does the Vf matter for spms? SFT40 seems to have lower Vf at 4A than W1 (FY and F1) (although djozz test of w1 F1 green seems weird it may had to do with a missed/bad solder job)
By the way, I am curious about how this driver is adjusted, is the voltage factory adjusted to match the higher Vf values of the LED, then current is controlled by the UI? ( I’m just picturing how this aliexpress spms I use is voltage and current adjustable through two small trimpots … I’m not super knowledgeable about how they interact with a load such as diode that forces a voltage drop (Vf) ).
I’ll also try to get a look at the markings on the big chips near the coil for you thefreeman
For the regulator JaredM helped me figure out the part here .
The driver is current regulated, the Vf of the LED doesn’t matter (as long as it’s a 1S LED).
As a rule, I would say no. Check this thread, it has some charts with efficiency and other data for a few boost drivers: Buck and Boost Drivers, Testing, Modding, and Discussion
The driver adjusts its output voltage by sensing the output current flow or current flow to the emitter. For this to happen the current goes through a sense resistor, usually a very low value power resistor located just before the negative output wire. Because current times resistance is voltage, this voltage drop at the sense resistor terminals is amplified and sent to the microcontroller. This is the way the microcontroller “senses” the output current and thus knows if the current flow is correct for any mode, and when not it either raises or lowers the output voltage. This is done at a very rapid pace, probably thousands of times per second although in this respect thefreeman can provide more accurate information.
Since buck drivers can only reduce the output voltage, not raise it, when the led requires an output voltage which is too close to the input voltage or even higher, the led won't receive the full current. This happens at some point as the battery is discharged and its voltage drops.
What do you mean with spms? Closest abbreviation to it I know is smps, for switch mode power supply… :D
I have a few of these buck modules. They are CC/CV DC-DC converters. You set them up by adjusting their potentiometers. Whatever voltage you set them at with their CV or constant voltage potentiometer will be the output voltage or maximum output voltage. When you don't need or don't want current regulation at all, you set the CC or constant current potentiometer all the way it goes (clockwise rotated, in my experience), this way you'll always see the full output voltage until the module protects itself because of some overcurrent or overheating problem. If you adjust the CC potentiometer and set some output current (connecting the leads from a multimeter in amperimeter mode is a way to see the output current, for example, at least if output voltage isn't too small), the module will reduce the output voltage if it senses that the output current is beyond the set value.
These modules are nice, I have a few at home, but because of the parts they use for current regulation (the onboard operational amplifier -LM358?- and linear voltage regulator, I guess) the will only work in CC or constant current mode if the input voltage is beyond a certain thresold, 6ish volts, close to 6.5V if I recall correctly. For this reason they cannot work in CC mode when fed with a 5V supply. This also happens in other similar DC-DC converters like the LM2577S-ADJ CC/CV SEPIC module (A.K.A. LM2577 CC/CV boost buck converter), and somewhat sucks.
P.S.: I would swap the current sense resistor in the Convoy 8A buck driver, with a 18mΩ (R018) for example the maximum output current would be 4.4̅4̅4̅A.
