I've been busy with the lathe. Dale asked me to do a copper, (I guess it's a pill) for his Solarforce M8. He wanted a couple of extra fins and he wanted it to look nice.
Dale packaged it to survive the most Armageddon.
I think there were 6 layers of that dense corrugated foam stuff...
I must say this is a damn sweet light. I'd like to have one myself.
I took a sh*t ton of measurements and put it all down on paper. Picture is my height gauge. It's well worth the money it cost for stuff like this.
The fins are .070" with .070 grooves which are .100" deep on the stock part. That was a bummer. My parting tool is .091". So I had to grind a special grooving tool. .070" is pretty thin so I made it short. Sorry, no pic of the groovy tool.
All threads on this light are 20TPI. I was surprised they were not metric.
I did a trial run in aluminum to see if my machining plan and math worked out ok. They did.
So, a-machining I did go... I am compelled to say that machining copper is sometimes a b*tch. Grooving especially is aggravating. It took me a while to figure out that I had to keep honing my grooving tool on a much more frequent basis than aluminum or even steel need.
Chucking it up and minimizing runout.
Boring the end for internal threads and the driver pocket. (Note the Mickey Mouse tool bit) It worked great in copper after a little fine tuning.
The dial (bottom left) is to tell me what my depth is.
Bored and OD turned. Freshly turned copper is damned pretty.
Shoulder turned. It took me a while to figure out the angle. I ended up using 31.5 degrees. It might be 31 or 32, but it wasn't 30. Grrr.
Groovyness in progress. Did I mention it was a b*tch?
Internal threads and groovyness done.
Jig for hole pattern for 20mm Noctigon.
Holes transferred and drilled.
Chucked back up after an endo and turned to diameter. I was shooting for 1.210".
I forgot to take pics of boring the hole. But by definition, it's BORING.
Here's a shot of doing the external threads at 20TPI. It was nerve wracking to try to take this while the lathe was actually cutting a thread.
The finished product.
Top
Bottom. I have to debur the wire holes yet. Dale really wanted to see all of these pics so I rushed the pics a little to get this thread done.
It has room for double stacked 7135's on both sides of the driver.
And finally...
I put an XM-L2 in to fit check. The pocket for the star seems just a shade low to me. I have a little meat that I can remove off of the top shoulder to raise it up if needed. Dale and I will decide before I ship it Monday.
This is how it will look when Dale opens the box after he removes the first 3 layers of protective packaging), hopefully on Wednesday.
My thoughts...
Copper is a different animal. I was able to do what I needed, but it is more difficult. I have some video of me making the grooves and it wasn't going well. Boring is somewhat more difficult than aluminum or steel too, but not as bad as grooving is.
I scrapped the first piece that I made after it was about 90% done. It had nothing to do with it being copper and everything to do with me being tired and turning on a hand wheel without thinking and going too far. I bored the LED star pocket too deep. Dale was willing to take it as it was and shim it with a second copper star, but I was not. I may re-machine it by removing one fin and groove and sell it to someone else if there is interest.
Lastly, I am please with how it turned out. I hope Dale is as well.
