I was pretty excited about this LED and the possibility of making customized multi-die emitters. I ordered some from Arrow electronics. Part number: XD16AWT-H0-0000-00000BJE3. Should be S2 flux bin. I measured the output, forward voltage, and resulting intensity in a flashlight.
I made a makeshift MCPCB out of 1.6mm thick copper. I glued two pieces of the copper together with JB weld so that there was a small gap. To electrically isolate the two pieces from the shelf I used a couple thin strips of kapton tape on the bottom of the board.
Output measurements:
I measured the lux above the LED with the lux meter 0.59m from the LED. Assuming the angular light distribution is that of a Lambertian emitter I can calculate the total lumen output if I know the luminous intensity (cd) above the LED. I explain this more in this thread, and it seems to be consistent with other users’ measurements of the LEDs. The below lumen numbers are calculated using this method. I stopped the measurement at 5A because I wanted to save it for other measurements.
The output is lower than I hoped. The good news is that the whole surface of the LED appears to be lit uniformly. I don’t know if the whole area is covered by the actual die, but it did not look like the outer parts were any dimmer (like with the nichia E21A). So I think an array of these really would look like one gigantic seamless die. I did notice some blue light escaping out from the side of the package, similar to other cree flip chip LEDs if the side-phosphor is removed.
I put the LED in an eagle eye X6 and measured the beam intensity at 4A. Unfortunately the number is a bit disappointing at 51.5Kcd measured at 6.78m. The LED was in near perfect focus.
I was really excited to make a 3x3 array of these, but the performance will not be nearly as good as I hoped. The efficiency seems to be not that great, and the effective luminance is also not high, which would have been an advantage over XHP50.2 and XHP70.2. Now I’m not sure if I will continue with the 3x3 array. I hope others will measure the XD16 to make sure my measurements are not far off.
Update:
I was suspecting that the die does not reach to the end of the package so I scraped the phosphor off one to see. With my calipers, the package is 1.60mm across, and the die is 1.38mm across.
