I think this driver will be excellent for use in low voltage situations as well. Is it possible to get one with a voltage range from .8 to 4.2v? I hate driver whine (PWM). I am all for digital, linear controlled drive currents.
A linear driver can only step down the voltage. An LED needs about 3V so it’s impossible to have an input voltage as low as .8V! You need a boost driver for that.
If you want I can make a topic to describe the main differences between Buck, Boost, and Linear, because it seems that many people don’t really understand that.
Any help and education is appreciated by me. But I guess what I was trying to say was that this would be good in a low voltage situation so as to not have any PWM whine. Whatever it takes to put it together, ie, with a buck, or boost driver, whatever it takes to complete the module.
Actually I need something like this, but I need it to a bike light with 7 XM-L2 in series (the stock driver delivers up to 650mA with 2S, so ~1500mA would be perfect).
How many leds can it handle? Will you make a bigger driver that can handle more LEDs?
Again, you need a boost driver as the voltage of seven LED in Series is higher than a 2S. I really need to make that thread.
This is a linear driver and can only yep down the voltage. It is perfect for one cell one emitter.
You do need to make that thread. You’ve probably already realized this, but there is actually a lot to explain if you extensively cover only the application considerations of buck/boost/linear/direct, assuming you include things like zener modded 7135 and FET drivers. If we had a clear post describing the topologies I’d definitely refer people to it, but an explanation of the effect of zener or [currently non existant] vreg mods on the 7135 and FET drivers is really essential for a lot of the questions we run into. Take a look at my post #14 in HiTiT’s thread. There was still some confusion after that, which I thought was a decently clear explanation. And if you write to many words, we’ll never get people to read it. Definitely a double-edged sword.
Ok, I’ll do it. I’ll start by explaining Buck, Boost, Linear, Direct Drive. I can always add things later (like Zener diodes, etc.).
I think I’ll do a first part “In a nutshell” and below that a more detailed version with graphs and things for people that want to understand how it really works. I’ll also insist on efficiency.
I only have two 7135 based drivers (I have 2 flashlights, I’m a noob! ) so I’ll have to buy a buck and boost driver if I want to plot some graphs. That will take time.
When led4power releases his driver I’ll try to include it. Unfortunately I didn’t win at the giveaway so that’ll have to wait.
I worked on a high end Buck driver used in Smartphones for 6 months as an intern, so I should be able to give some accurate infos, but I WILL make mistakes so you’ll have to check what I say.
Yes,it has.If voltage drops <3V,current is limited to ~150mA.You still can use modes lower than that (moonlight and low it this case),but if you switch to mode with >150mA,current drops to 150mA.If voltage drops <2,8V drivers goes into sleep (~50uA).
Last minute decision: board will be 4-layer for better thermal performance.Now question about pcb thickness:will 1.2mm cause any problems?
I tested driver in roche f8 host,first without any potting,and I noticed one (expected) problem: driver temp!=flashlight temp.
This is because thermal contact driver-flashlight isn't so good(potting improves that and it's highly recommended for this driver),so small flashlight heats up much faster than driver(and opposite,driver temp is higher at 1Amp,than at 5Amp,because more power is dissipated).
This means over temp protection doesn't work well if you don't have separate sensor for LED/flashlight body.But I partially solved this problem with two temp thresholds: one driver overtemp threshold(for ex. 100C),that can't be changed by user and it's always on.It prevents driver from failure caused by overheating.Second,lower overtemp threshold can be set/reset by user(reset value is equal to driver overtemp threshold) as described in OP.It's active only on highest mode.Not ideal,but for now it's best solution.
