Not a common question but where’s the best place (price) to get these and any charger that can do 12 (yes twelve as I plan to get a boombox that runs off 12 D) :party:
Not even! Tenergy D batteries are some of the best you can get. And they only cost around $16 for two at all-battery.com. At this price, why bother with Eneloops in adaptors?
On the other hand, the charger is going to be a little more problematic. I’ve not heard of a 12 bay charger for D cells. Most are four bay. And I think I’ve heard of a charger or two that have eight bays. But for 12 bays, you might have to go with multiple chargers.
Use a bench PSU to charge the batteries. Put all 12 batteries in series and use the constant current setting of the PSU. You will need manually overlook the charging process.
Keep in mind that, not only will you have to monitor the entire charging process. But a good power supply isn’t cheap. Plus, charging NiMH batteries together in parallel or series is NEVER a good idea, as it will ALWAYS overcharge some of your batteries (thus shortening the life). On the other hand, you can buy a decent, budget charger that has everything you need (like independent charging channels) for under $30. Even if you buy two or three, you will probably be doing better than if you buy a good power supply.
A good charger to consider would be the Tenergy TN190. It certainly is ’t the fanciest charger out there. It won’t tell you the capacity of your batteries. But it has all the basics covered, including -dV smart charging, independent channels, and a discharge function for conditioning batteries. And it WILL charge D’s. The cost? About $27.
It would be a lot more practical to add a connector to allow the boom box to run off a 4s or 5s LiPo, and use a hobby charger. The battery should easily fit in the space for the 12 D cells, and would be considerably lighter, too.
How often will you go through the batteries? I may pay to buy twice as many batteries and one charger that way you can have a reserve set already charged while you are charging the other set. Otherwise, getting 3 chargers is probably your best bet.
Ive read here on BLF, that those super-cheap Tenergy cells come from warehouse that was ruined during fire, many Tenergy cheapo-cell owners have reported that they dont last long and are hit/miss quality.
12xD questionable quality cells will set you back huge amount of money compared to using 2AA-D/3AA-D adaptors with 2000/2400/2500 LSD NiMh batteries in them.
Then there would be unequal current draw, right? The 2 paralleled eneloops would provide 4 amps vs 2 amps in the 3 aa D (series) adaptor (thats if you try to mix the 2)
