Dandyhorse's entry for the 12th Old lumens challenge. Modified flashlight category
Hey everyone, I watched this competition last year but didn’t take part but this year I want to use this as motivation to actually finish a project.
I have this orange Convoy C8+ that was my first dedicated thrower when I first got into the flashlight hobby. I have since gotten throwers that I like more but want to be able to use this host for something fun and I found a lens that fits it well so I would like to make this 1xSFT40 thrower into a 7x519A flooder.
8 Thanks
Here’s what I have currently. I need to order a couple more things and design some stuff to make this work. My current task is 3d modeling the inside of the head to make an insert
Good to see you enter! Looking forward to see what you do.
Thanks! I’m excited to see how your build turns out too
Oh man! I’m excited to see this come to life! Best of luck to ya!
Thanks, I’m excited to be a part of this!
Currently it looks like there is a growth coming out of the host so that’s a great sign. I’m using air dry clay to get the internal dimensions of the flashlight. I will check sizing with some 3d prints afterward
Now THAT is a cool idea! You sir are a genius!
I’ve done that a little bit in the past to get patterns to make small metal or wood parts, but its been a loooong time ago, and it had not occurred to me to do it for 3D printing!
Thanks! I haven’t printed anything yet to test actual fit yet but here’s the model I made with guessing and calipers vs the model I made with the clay model.
I’m really interested in this part. I’ve had an idea to convert a similar light to say a triple TIR (by gluing together three separate TIRs). I would have the same kind of situation you’re dealing with here. That looks like a great approach.
Did you have to use any kind of “release compound” for the clay? And did it shrink much as it dried?
No I just used some air dry clay and let it dry for 24 hours before removing it. The clay that was inside the light definitely wasn’t fully dry when I pulled it out but it didn’t take too long afterwards. I’m expecting that it shrank a little but it was still a pretty tight fit when I removed it so we’ll see
If you do this I would definitely recommend using a color (or colors) with more contrast. The edges of the blue and orange were a little hard to make out sometimes. Black would probably be the best, or a black and white mix.
Looking forward to see how your flooder turns out Dandyhorse!
Of course my 3d printer picked the best time to break so I had to fix that but luckily it is back up and working!
After 12 iterations I finally found a spacer design that works well, next will be getting it machined.
Also my optic came! I decided on the Ledil Anna 7 emitter 15 degree spot optic to try and get as much throw as I can. If I ever want more flood I can always throw some diffusion film or sand the optic
Now on to mcpcb design!
I also ordered the Convoy 17mm 3v 8a buck driver but sadly it will take a while to get here
This is my first time using Autocad (Eagle) for PCB design and it wasn’t too bad! Off to JLCPCB!
The 3v8A buck driver arrived! I needed to add a few more things to get over the $5 threshold for free shipping from Convoy so I picked up some glow in the dark switch boots. I really like the blue with the orange aluminum.
6 Thanks
PCBs Arrived! Time to reflow the emitters.
I had to test everything with the driver and it works!
Be careful when screwing down the bezel if there is nothing holding down the lens. There is a fairly high chance of shearing the domes off the 519A emitters.
Better add an adapter to hold the TIR in place.
Is the emitter center heatsink pad connected to the metal of the PCB? Hope it is the case so they can cool properly.
Interesting project!
