The NYMPH is Darkside’s first product offering… [redacted]
It’s a compact 10440 twisty with a Fet+1 driver, a Nichia 4k 9050 219C LED, and an integrated grade 5 titanium pocket clip. The light features what I am calling a “sinusoidal knurl” pattern:
The 10mm driver is a single sided ATtiny13a based fet+1 called the “DS-10DD+1” and is basically an evolution of the MTN-10DD by RMM. I’ve ditched the OTC, using mem decay for offtime instead, added a vertically oriented 7135, and external programming pads so that the mcu can be flashed in situ. A pogo pin programming clip will be available later.
The LED is a Nichia 219C, 4000k 9050 CRI, on a 10mm copper DTP board. The negative contact spring is silver plated BeCu and the positive contact button is pure nickel, though I may switch to a bi-metal contact.
The stock firmware (written by ToyKeeper) has SIX MODES, + battery check:
- 1: ~.8 lumen (moon) [50+ hours](need to retest this mode)
- 2: 9 lumens (low 2) [9 hours, 10 minutes]
- 3: 37 lumens (medium 1) [2 hours, 23 minutes]
- 4: 130 lumens (medium 2) [39 minutes]
- 5: 340 lumens (high) [12 minutes]
- 6: 700+ TURBO lumens: 1 second soft start from 340 to 700+ then the firmware slowly ramps the output down to around 340 lumens @ 30 seconds. [8+ cycles to 30 seconds]
- 7: Battery voltage indicator mode blinks to indicate state of charge. Volts + tenths blinkout by default. (4.2V is max charge, 3.0V is completely empty)
The light cycles from low to high and always turns on in mode one. The soft start on turbo allows the light to be cycled through to the battery check mode without having to blast turbo to get there. It also serves to pull down the battery voltage a bit before going to 100% FET, which is easier on the LED and battery. The firmware will be open source and the link released at a later date.
The exact mode values may change slightly before launch but it’s pretty close, and these are the mode values I used to get my runtime numbers.
The current spacing values are based on what level_calc.py spits out when I put my preferences in there:
1: visually 0.96 (0.83 lm): 5.00/255, 0.00/255
2: visually 1.52 (8.18 lm): 20.42/255, 0.00/255
3: visually 2.08 (39.07 lm): 85.22/255, 0.00/255
4: visually 2.64 (128.35 lm): 255.00/255, 7.21/255
5: visually 3.20 (335.27 lm): 255.00/255, 89.69/255
6: visually 3.76 (750.00 lm): 0.00/255, 255.00/255
PWM1 values: 5,20,85,255,255,0
PWM2 values: 0,0,0,7,90,255
The SPECS:
- FORMAT: 10440 TWISTY.
- BATTERY: 10440 IMR CHEMISTRY LITHIUM ION CELL. (Not included. Does NOT operate on NiMH or alkaline cells)
- BODY: Aluminum alloy. (may use 7075 if the ano comes out good, otherwise 6061)
- FINISH: Type III, class II hard anodize finish.
- POCKET CLIP: Ti6Al4V Grade 5 Titanium.
- OPTIC: Diffused spot polycarbonate TIR, 27° FWHM, 91% efficiency.
- Heatsink: Copper.
- LED: NICHIA 219C, 4000K color temperature, 9050 high color rendition. (MIN 90 CRI, MIN 50 R9 deep red)
- MCPCB: Copper, Direct Thermal Path.
- DRIVER: “DS-10DD+1” 10mm ATtiny13a based FET+1 driver with reverse polarity and low voltage protection. External programming headers allow for in situ mcu flashing.
- MODES: 6 modes + battery voltage indicator mode as the 7th mode. L—>H, No memory.
- POSITIVE BATTERY CONTACT: High conductivity pure nickel.
- NEGATIVE BATTERY SPRING: High conductivity silver plated beryllium copper.
- WEIGHT: 15.5 grams without battery, 24.6 grams with battery.
- SIZE: 65mm total length including clip protrusion, 15.4mm head diameter.
- MIN OUTPUT: Approximately .8 lumen with stock firmware. (Raptor claw 7135, so firefly is possible.)
- MAX TURBO OUTPUT: 700+ lumens.
- LEAD FREE SOLDER is used throughout the light.
Feel free to ask any questions and make commentary! Thanks so much for your support!
