Looks like this one already has a Nanjg 105C driver in it, you can add 7135 chips to this to increase the power to the LED, the other one you would need to completely replace the driver
Extra options on the 105C in my mind is worth it, but only 3* chips means it's only pushing 1050A to the emitter, not a whole lot of power
But 99.4% of buyers enjoyed this product! (230 votes) 263 orders (230 out of 260 give good reviews)
Does BLF coupon work to drive that aliexpress one down a bit?
On EBay, I ordered a C8 for about $8.
Their ad said it was a TrustFire, the display had a picture of a KinFire, what was sent was an UltraFire……but what I really got was a CrapFire.
With that cheap P60 flashlights prepare that not only driver is low quality. The pill is most likely made of aluminium (just painted yellow to imitate brass) and is hollow - with an emitter cooking in the air. Not to mention short threads, low build quality, these new cheap ultrafires are much worse then the old ones. Here’s a comparison with older 502B:
I’m not sure about the quality of the host but the driver is the standard Nanjg with 7135s. I also thought aluminium has better heat transfer than the brass. Which is it?
I sent him a private message. I ask quotation for a 4x7135 (6x it’s too much for this host) and neutral XML2.
I’ll wait for reply. Thanks for the hint!
Hey
In this thread UltraFire WF 502B stare i nowe - www.swiatelka.pl you can see how pill looks like in cheap wf-502.
Pill has big hole under the MCPCB and is made from aluminium… LED probably will burn in 5min.
this is one of my favorite EDC light as it’s feel like solid and you can drop it many times and the price you will not cry about it
bought at least 8 for gifts already, for around $10 with XM-L2? it’s a no brainer everyone should own at least one of these :bigsmile:
swap the lens with 28mm aspheric lens from DX for more throw! D
I have the two I mentioned above that I put together, for GP flashlights, 1 mode though
I will be either swapping them for a STAR V1.1 firmware or one of the new FET drivers when I get them in and build one…they really are good “budget” lights (just make sure you aluminum foil heatsink the P60 dropin)
Can’t even get the host and the driver for that price!
true that on the price… but FET driver in this light? lol over kill… but definitely will gather a lot of WOWs … :bigsmile:
even simple mod such as swapped the LED to XP-E2 on noctigon with 3 Amp driver and coupled with 28mm aspheric lens makes this a small killer light for under $15 :bigsmile:
