Detailed parameters.
Model number: K80
Material: aluminum alloy.
Shell color: black, silver.
Oxidation process description: silver is ordinary anodizing treatment, black is hard anodizing treatment.
Low pressure warning: yes.
Anti-polarity protection: yes.
Lens type: double-sided green film plating.
Reflectors: smooth surface.
Switch position: middle side press.
Pattern memory: yes.
Tail handstand: yes.
Waterproof grade: IPX6.
Charging current: up to 3A (only A TO C charging lines are supported).
Battery chargers include: not included.
Use battery type:
LED:SBT90/sst40.
Color temperature:
LED substrate: 25mm.
Circuit warehouse:
Size: head diameter: 80mm battery compartment diameter: 36mm flashlight length: 26800 version 190mm (26980 version is 210mm).
Diameter of battery compartment: 27mm.
Net weight of the product: about 500g.
Complimentary: waterproof ring * 2, key rubber cap * 1, charging rubber cap * 1, hand rope * 1, A to C charging line * 1.
Flashlight with low voltage protection and temperature control protection, the temperature reaches 60-65 degrees temperature control begins to control downshift.
Circuit board drive output description:
SBT90/SFH55 version:
Output voltage: 3V.
Output current: 22A~25A (the output current of the driver board is determined according to the output current of the battery, up to 25A).
SST40/SFT40 version:
Output voltage: 3V.
Output current: 8A
Gear operation instructions:
Gear order:
0.1% - 10% - 50% - 100%.
Click to power on(remember to open the previous gear),
Long press change gear mode.
Double-click extremely bright (100%, can be remembered),
Three-strike flash mode (100%).
