EDIT: At this point, I do not recommend this light as an MT-G2 host. See post 5 for additional information. I intend to finish this light, but I would not have purchased it had I known what I know now.
Just received my Digital Projector Spotlight (also called Wideshine) today. It cost me $43.11. The beam is awesome. This would be interesting with a dedomed xml. It has a big hot spot that goes straight out and doesn’t seem to grow wider. The hot spot is dark in the center at close range. The dark spot fill in completely and the beam seem uniform after a distance. It has a faint usable wide spill.
Shining up into the sky, the beam is dimmer, but visible further out than my modded TN31. I haven’t even had a chance to fully charge the built in battery yet. Targeting objects 800-900 feet out, the hot spot is larger than the TN31, but not nearly as bright. Nicely lit up though. The TN31 is dedomed and has a much more intense, but small hot spot. Keep in mind that the TN31 modded and currently pulling 381kcd. I don’t know why the beam appears to go out further into the night sky.
EDIT: Fully charged I am measuring 100kcd (2,090lux at 22’9”). They were measuring 110kcd in the thread linked below. Their higher reading makes sense to me because they were measuring at a further distance (32.8 feet). The beam from this light needs a good distance to fall together.
This light is so much more portable then the Defiant spotlight that I modded. That’s due to it’s shape and the handle not sticking straight out. It’s real comfortable to carry with the shoulder strap. It tucks behind you and you can forget your carrying it.
The aluminum part of the body does not appear to be large enough to displace the heat of the over driven dedomed MTG2 I plan on using. But since the body is straight (not curvy and plastic like the Defiant), I can attach a lot of heat sink fins it. Here is a thread on the light. I tried to get it moving again, but got no response. So I’m starting my own thread here. I hope to make it rock in a big way.
Here is a link to the current listing from vendor I purchased from:
I can tell already, this light is going to be fun, fun, fun!
2 lousy phone pics:
