No, it cycles readings trough all cells it can find. In this case only one, so it shows only the one you are testnig. It does blinking between readings trying to find next, but it's not annoying. And it consumes very little power from the battery.
So what does it do for the unmeasured cells? What do you mean by blinking?
Sorry for the questions, I’m just curious because I’ve ordered a similar one last week, I guess it should be arriving next week or so. I’m just looking for a very compact single cell volt meter I can incorporate into a battery pack.
One I had earlier would cycle through all 6 cells, even if they measured 0 volts. So what I’m after is one that only shows the voltage of the connected cells, and no zeros.
You might get it bit wrong. It's just a checker. The charger doesn't work. In fact I took out all the electronics. Still your idea isn't bad. BTW I'm mostly using XTAR WP2 and Ultrafire TR001.
Cool to have videos these days. Mine looks to be similar to the one you have interns of layout and design. The UI seems pretty similar across most of the current volt meters now. I’ll try to find a link later from eBay.
I like the way it handles the single cell, it’s pretty smart now. The ones that I was looking at a year ago would simply flash through all cell voltages and start again, so you get slot of zeros.
You might use also 2s-6s checker, but you have to check at least two batteries at same time. AFAIK those are not so accurate and you might get a bit different electronics as shown on pictures. Still usable
plugging the batteris into your icharge will do the same thing and it has monitor mode as well as im sure you know, but these are great if people dont have hobby chargers and they are great out in the feild not at home near your charger or DDM.
