DIY World’s Brightest Single LED Flashlight
Compact…
Not like the one Hacksmith made
If you always wanted MORE light to destroy that ugly darkness, I have the solution
Well, I will have.
Because I have the world’s brightest LED
This beast can output up to 120 000 lumens
and consumes more power than my oven.
It uses more power than any of the items I use on a daily basis.
I can use hair dryer while watching TV, washing clothes in the washing machine, charging my phone and laptop, with all lights in the house turned on and this single LED will still use more power than all those things combined.
2000W is a lot of power. How to power this thing? One 21700 won’t be enough, I guess…
Ok but let’s start from the beginning:
This massive LED is produced by Yuji: a company specializing at high quality LED technology.
Well, but many companies can say that. “We are the best”
But how many companies will have their LEDs installed as one of the main light on the International Space Station (ISS)?
Not many
Now when we know Yuji is a serious company, let’s see what you can buy in their store.
You can buy this connector:
Or this pretty expensive cable. Looks like regular cable to me, not sure why it’s so expensive:
If you need high quality LED, you can order this one:
10pcs, so $7 for one
Or you can buy this massive beast:
If you are worried about bringing new flashlight and explaining to your wife you really need this one (and it’s different than 37 other flashlights you already have) imagine bringing this single LED and explaining why you really need this small round disc that is more expensive than your car.
Well…anyway, let’s go back to main topic
Here are some specs if you are interested
And a closeup
But what makes this particular LED special and better than…idk, this?
Some may argue that this one uses 4 Nuclear…something, but keep in mind this is different technology and my flashlight won’t have any Nuclear…things.
This was a bad example, but what about this one? Why buying expensive LED if you can buy a whole flashlight for a fraction of the price
__
Sadly, it’s no longer available. Seems like it’s very popular and manufacturer can’t keep up with production
__
Having nearly 9 million lumens it sure is hot!
But what will make my flashlight better than this one?
Mine will have better range
I mean if you produced flashlight that has nearly 9 million lumens and only 1500 meters range, you definitely should go back to drawing board. Or sell your business and move on.
Ok, enough jokes
I will try to make the brightest single LED flashlight in the world using this yellow disc. Pretty well engineered disc. But still disc.
In theory, everything is simple:
Unbox the LED:
That was easy! I hope next steps will be easy too.
Find sufficient cooling solution
I don’t think the regular passive cooling would be enough.
On the other hand, I found this flashlight
They are using copper heatsink, very clever, because as we know copper dissipates heat better than aluminium.
I know, 600W is not as much as 2000W, but maybe I can find slightly bigger copper plate and it will be just fine.
Think how to power this thing
Perfect
Or even better
And it’s not even that expensive. I can order 6 to have a total of 119400mAh
At first I was afraid it’s not true and real capacity is lower than described, but then I saw this
I feel stupid for even thinking of questioning anything they put on the website.
Find good body for the whole flashlight
Well, the LED itself is bigger than the whole reflector of my Convoy L8. And L8 has already a massive diameter.
This thing is simply huge when compared to regular size LEDs
It’s even almost as big as a whole 18650 flashlight
You might not have L8 or an old flashlight, so I compared the LED to more common things
It’s slightly smaller than the orange, but I must admit, this orange is pretty big
So…the whole flashlight will be bigger than a standard big flashlight, but it will be significantly smaller than this thing made by Hacksmith:
I have one more picture, here is my huge mug for size reference
Alright, I just wanted to show off my mug
And that sounds like it. As simple as that.
