I will just start a thread now, all hobby time this whole summer was filled with catching up with other projects, and now the deadline is already not too far away: just starting this thread might help me making slow progress. I do not expect finishing before the deadline, but I'm ok with that.
The plan is a small lantern for camping, working on 3 AA batteries. This is some stuff that will be used:
Here's already a challenge for the judges :bigsmile: : the 3xAA battery carrier was already made last year, because this build was already planned for last year's contest, but I never got further than the carrier. So it is not build within the time frame of this year's contest (build thread of the carrier). Further, there's a piece of plumbing copper, a brass coupling, a Philips household bulb (I will just rob the optic) and a 3000K 83CRI Nichia 219C led. I chose the new 219C because the extremely low Vf makes it great for use on 3xAAbatteries.
Teardown of the Philips bulb.
I have already posted about this bulb 2.5 years ago, link. I just want the optic, but I was also interested in the build of this bulb, so here's a complete teardown. First the clear plastic outer bulb was simply twisted off, it is glued, but not that tight.
That optic looks like it is really easy to re-use, a nice flat base screwed over the ledboard, great!
I found an intruiging led under the optic :-)
I tried lighting it up with my led tester but did not get it to work. Then I noticed that the four leds are connected in series, so two red plus two white would be ~11V. But my power supply even at 30V would not light it up. So now I think it is actually a 220V led! All those red bits are separate leds in series and the white ones are sort of COB leds. I did manage to get some very dim light out of it by touching one of the connections with my finger (I'm a cap man!), the power supply (my old small one) apparently lets through some 220V ripple or something.
LOL, there's a defective led in the left red section!
The electronics (of which I only have basic knowledge) indeed show no conversion to low voltage, I see some caps, resistors a rectifier and a fuse.
But I digress, hopefully to be continued later with progress of the build...
