Hi,
I made a “shorty” STL-V6 recently:
and since the STL-V6 is now direct drive, I’ve been trying to improve the heatsinking a bit.
The way that the FandyFire STL-V6 that I have is designed, there’s a brass pill, which screws into the reflector from the tube end, and then the reflector+pill screws into the head from the front end.
So, the front end of the pill, where the emitter is, screws into the back end of the reflector, which screws into the front end of the head.
Thus, the thermal path from the XP-G2 emitter is through the star (just a regular star, from IS), which is glued using Arctic Alumina to another larger 25mm star (which I sanded the face - long story), to the pill, to the reflector, and finally to the head.
I initially just put some Arctic Silver 5 on the pill threads and on the reflector threads, but I didn’t think that it was good enough (the head wasn’t getting very warm), so I ran out of AS5, so I used some thermal grease I got from FastTech awhile ago:
https://www.fasttech.com/p/1148100
I also took a narrow strip-shaped Fujipoly thermal pad, and shoved it around the edge of the emitter PCBs on the front of the pill. Since the pill screws into back end of the reflector, my theory was that that would increase contact from the emitter PCB to the reflector.
This actually seemed to have worked, as the fins around the head now get pretty warm, almost hot, pretty quickly now.
So then, I was doing a timed test, to get an idea of how hot that would get, and I had the light tailstanding on my desk. When I did that, after awhile, I noticed that when I looked at light, the area inside the front looked a little “bluish”.
I quickly turned the light off, because I thought that I was seeing that bluish color because the emitter might be getting killed, then I waited awhile and then turned the light on, and it was fine, no more bluishness.
I did that a couple of times, and so far the same thing happens each time, and the last time, I noticed that in addition to the bluishness, it was kind of “foggy”.
However, when I turn the light off, the lens is still clear.
So, I’m wondering what is going on, and also wondering if maybe, as the light heats up, either that thermal paste or the thermal pad is “outgassing”, and since the reflector is in place, whatever it’s outgassing is remaining inside the head, and eventually becomes visible in the form of the “blue fogginess”.
I’ve googled and it seems like it might explain what might be happening, e.g.:
and:
Has anyone seen something like that with a flashlight where you added thermal paste or pads, and also, is it a problem long-term? I’m wondering if that is what’s happening, it might deposit a film on the inside of the lens?
Thanks,
Jim
