Made a little progress today so I thought I’d post some pictures, sorry in advance for my photography skills.
This is what I started with.
3/4 OD copper rod, 3/4 ID copper pipe, a couple of triple XP-Gs (one cool white one neutral), a couple of brass pills (compliments of E-1320, thank you), some Carlco optics and various left over reflectors and springs.
I used a 3/4”, spring steel hose clamp as a guide for getting my cuts square, it also worked well when filing the copper rod.
After cutting the rod to length I filed one end down to fit the brass pill and clamped them together with AA epoxy.
Once the AA set up I drilled a hole through the center and cut two lengths of pipe to go over the whole thing.
I soldered the pipe over the copper/brass leaving the pill recessed about 1-2mm below the pipe. The space between the pipe and rod is filled with solder so I think it should transfer heat well.
If you’re wondering why there’s only one pill in the next few pictures it’s because the second one didn’t work out the first time. I heated the rod first then dropped the pipe over it and applies solder, worked great the first time. On the second one the AA gave up the ghost just as I started applying the solder. I must have overheated the rod. I cleaned everything up and will try again tonight.
At any rate, one came out good.
This photo shows how nicely 3/4 copper pipe fits in an L2, in this case my L2I though that’s not where it will eventually end up. It fits with less clearance than a standard P60.
File down the star and it sits on the pill flush with the edge of the pipe, snaps in like it was made to be there.
I’m waiting on the drivers and still need to pick up some teflon wire (anyone want to advise me on what gage wire I should use for a 3A driver?).
I couldn’t resist seeing what it will look like when done. Since the optic is only 20mm I needed something to fill the space in the 26mm L2 head. I cut off the end of couple of unused P60 reflectors and filed them down to the correct height. They rest on the pipe and don’t even come in contact with the optic. If they seem to effect the beam I’ll scuff them up and paint flat black. Photo below is next to a S/F single SP-G drop in.
And one more of what it looks like in the light.
I’ll update once I have them all together, the only part I’m worried about now is the soldering. I’ve done quite a bit in my time but this stuff is tiny!
