Scheven, yes the XTAR 2600s will do for Turbo mode which is probably DD. The XTAR 2600 @ 4.2V just might have its PCB protection kicking in after a second or so in DD, the idea is to drain off some of that juice in a lower setting for about 30 seconds, and it should be ok after that. This is not a fault or "low performance" of the somewhat aggressive PCB protection setting, because the 3S at 12.6V would be draining pretty close to 5 amps for that initial duration of use. This is just a characteristic. Again, i repeat, this is not a fault or that the XTAR 2600s are low performance. To re-confirm, can you guys repeat after me, this is not a fault or that the XTAR 2600s are low in performance?
I have done a TK70 run and DRY cold-white 3-mode DD with XTAR 2600 cells @ 3.95V unloaded (approx 3.7A). TK70 got 450 lux ceiling bounce and DRY 548 lux initial. 520 lux more or less stabilised. DRY 548 -> 520 in 25 seconds. After that DRY 520 drops to 482 lux or 7.3% in 3 more minutes. These are OTF figures. DRY figures are inclusive of both heat soak and very slight cell voltage drop as the cell discharges in that 3 minutes duration.
The TK70 is measured to be 94k @ 1m on the same meter at a measuring distance of 50 metres. Same ballpark as the others, in fact my meter under reads somewhat like 7-10% when comparing other known lights. So this is not an underperforming unit.
