Duv is reported to 4 decimal places most often (e.g. +0.0078 or -0.0014). I find it difficult to read or quickly compare - and also excessive.
I’m not entirely sure, but in the flashlight context anything less than ±0.001 seems indistinguishable. That’s on top of the spectrometers used unlikely being that accurate or even precise.
The two values above stated as +0.008 or -0.001 are way more transparent and meaningful to me.
While it’s not exactly a ratio, I started writing them as percentiles (+8‰ or -1‰) - to me much easier to look at, not to mention quickly grasp what the tint may be.
I personally think what counts is not the number of decimal places, but the number of significant figures. Having 2 sig figs only guarantees an accuracy of +/-6%, which is IMO not excessive, assuming that the measuring instrument is capable of such precision. If the instrument is incapable of such precision, then the extra sig figs are misleading. (Looking at you, Opple…)
Though one can argue that since duv is not a physical quantity, perhaps error should be measured additively rather than multiplicatively.
They’re indistinguishable without a side-by-side comparison for the vast majority of people, though still detectable with such a comparison. The perturbation of duv by a typical AR coating is on about this order; even less for green versus uncoated.
I do agree that writing 0.0078 duv is cumbersome notation. Since duv is “naturally” measured in increments of 0.001, it seems more sensible to use the unit milli-duv, i.e., 7.8 mduv.
I think it would be great if the community got together and agreed to report it more easily.
I can’t remember who it is (Cheule?), but I recall someone referring to “points” of DUV and 0.0078 would be 78 points. Unfortunately there is no metric prefix for that.
I think that would be easier for people to wrap their heads around and talk about.
I still think that the second s.f. is unwarranted or at least reporting it is not too useful, even if the spectrometer + method can actually resolve it.
I think the differences between various reports for the same light or between slightly different levels by the same setup are more likely to be in a few if not tens of (10^3)×Duv, before even considering if the just-noticable difference could be less than 1 milli-Duv.
p.s. I doesn’t change the value or utility and I like the milli = 10^-3 part, but since Duv is a unitless quantity it may be a bit fishy a notation mathematically using SI conventions.
Duv ≈ +0.008 = +8 × 10^-3
milli = 10^-3
kilo = 10^3
So kilo-Duv = 8 or milli-Duv = 8×10^-6 ?
The SI prefixes are defined as above, but normally they are attached to units not quantities - they may become more awkward than helpful otherwise.
It’s hair-splitting, and mDuv looks much better, but I don’t know how to write it simply yet still properly. Percentiles ‰ or ppt is a practical option, but Duv is not quite a fraction either.
Maybe call it something else, like ‘tint index’ or similar but that may be too revolutionary…
I’ve been using units of mduv (milli-duv) for years. Not sure when I started, exactly, but it was at least 7 years ago:
The “duv” measurement is a delta U/V on an ANSI white color chart. It doesn’t really have units, but a delta of 1 is way too big for our purposes, while a delta of 0.001 is just about right, so… I’m a fan of “mduv”. It lets us talk about common values in a nice convenient range of single-digit numbers, like -5 mduv at 4000K looks nice, while +5 mduv at 4000K looks neon yellow-green like cartoon radioactive waste.
When talking about a range like -0.005 to +0.005, it doesn’t sound like it should make a meaningful difference. It looks too small to matter. But I think a different unit communicates the magnitude better.
I think mduv makes sense if you think of ‘duv’ as an invented unit (as in Duv = +5 mduv). And it looks neat!
The papers above support the notion that reporting mduv as a whole number (i.e. ±0.5) also makes sense - and that’s only accounting for what can be distinguished by eye in the best of conditions, side by side. Plus, I’m pretty sure that the instrument+method uncertainty in reported Duv values is more than that.
For side-by-side comparisons, it seems that a nontrivial proportion of people can still tell tint differences less than 1 mduv apart, though this appears to drop with higher CCT.
My eyes must be phukt…I can see some differences in the bottom four reds, but they appear counterintuitively to me…and the longer I look, the less convinced I am that there’s enough of a difference for me to tell WITHOUT a direct comparison…
That’s before correcting for false positives - they can also tell the difference where there is none :-).
Just-noticable difference (JND) attempts to correct for it to reflect what can actually be told apart vs. what’s imagined - the lowest a few of us can somewhat reliably see.
For most purposes and for most people, I’m inclined to agree.
Assuming that the instrument accuracy is up to the job of measuring to 0.1mduv, I think it would be good to report both sig figs–it only takes typing one more character and would be useful to at least 15% of users in some settings, which is quite a nontrivial number of people.
Additionally, I get the sense that eyeballing duv is an acquired skill, and that someone who collects high CRI lights for fun might have a much sharper eye than the typical participant in the study. My ability to eyeball CRI has certainly improved tremendously over the years in the hobby–in my earlier years I could barely tell a nice-tinted 70CRI Cree from sunlight. Same goes for my ability to identify pitch after years of musical training. For this reason, the above study might not be applicable for hobbyists or tint-snobs.
Also: I think that side-by-side juxtaposition of slightly different tints is a phenomenon that arises naturally, e.g., in angular tint shift in the same beam. Being able to accurately quantify such phenomena would likely require reporting mduv after the decimal point.
Sorry I missed the table above while typing the earlier comment!
I’m aware that the following is not your claim, but for anyone else reading, I’d like to point out that the table above does not say as much about equipment accuracy as it appears. Most flashlights have serious variation in color across the beam, and even a tiny offset in measuring location can have a significant effect on the measured tint. There’s a 0% probability that two devices are measuring the same exact spot in the beam; for this reason, one needs to control for error introduced by measurement methodology (by resetting and taking multiple measurements of the same light by the same device) before inferring anything meaningful about variation across different devices.
That said, the tables above do capture the combined variation in equipment accuracy and measurement methodology, neither of which is controlled by most users. For this reason, I think they do support your suggestion that reporting mduv beyond the decimal point offers no additional information!
I think it would be genuinely helpful/constructive to post this table over to that thread.
Sooo, which device is providing near accurate results? Maybe we shouldn’t be using these cheap Opple Meters for reviews, at least not without a measurement from a calibrated spectrometer to verify which is closest.
