I have this message “Things don’t appear to be working at the moment. Please try again later. ” while redirecting to PP page .In other shops everything is OK.
Question for all regarding driver efficiency between the M43 and the D18.
Low VF leds excess voltage will burn off as heat in the D18 when running on 7135’s.
M43 will be more efficient in terms of how it takes advantage of the low Vf LEDs due to the boost driver.
Do you think the extra 6 LED’s in the D18 will offset the efficiency loss compared to the Boost driver of the Meteor?
Of cause!
The flashlight is claimed as working only with button tops and the batteries are sold together with the flashlight. So they must be button tops.
I think you can use each flat tops where the top is higher than the heatshrink-tube. That schould be ok with all flat top, except with samsung batteries, from my experimence.
Hank seems open to producing a 3x18350 tube if there is enough interest here. But since he just asked us about this a week ago, I suspect 18350 tubes, if they are produced, won’t be available for some time.
I just looked at his XPL HI pricing. Hank charges $9.64 extra for XPL HI's on the D4, $15 extra on the D4S. So those are 4 LED's, and for 18 LED's, if you use the same rate as the D4S then it would be $67.50 extra for the D18. This is of course if the XPL HI's work ok with that optic he's using, and he's willing to offer them. He doesn't have a whole lot of bare XPL HI's in stock right now, and at 18 a clip, he'd go through his inventory pretty quick, but I'd assume he would only offer them if he had or could get them quick.
I was think'n about ordering 20 XPL HI 5D's from him with a D18, but the cost of the LED's is $4/LED in qty 10+, so $80 for the LED's.
