Update #3 :
Groupbuy ended , but there is a coupon for 15% discount available :
Coupon: UT02GB
Price: 42.46$ (15% off , when products not at sales )
Update #2 :
Dale’s review and comparison with Manker U21 here : Utorch UT02 vs Manker U21, group buy review for UT02
Update :
I tested a Manker U21 too , and as Dale posted too there are only small differences .
NW version has slighlty lower intensity 84 - 88 kcd , while CW has 95 - 98 kcd (measurements from various testers) .
There isn’t any problem with the light and it’s driver is same with Manker U21 (current production) .
Coupon will be still available for 10 days .
Utorch UT02 - Small Functional Thrower
Utilizing Cree’s high intensity flagship XHP35 HI LED, the UT02 provides an incredible illumination that is up to 1300 Lumens. It features versatile modes including 5 constant outputs as well as Strobe and SOS, which which is designed for a wide variety of applications. Onboard with Micro USB charging port and protection circuit, the UT02 gives you the rechargeable convenience. High intensity LED and precision reflecting system provide up to 700 meters’ throw, which is perfect for large area search and outdoor activities. It is compact but functional, well-built and incredibly powerful!
Brand: Utorch
Model: UT02
Lamp Beads: Cree XHP35 HI
Emitters Quantity: 1
Lumens Range: >1000Lumens
Luminous Flux: 1300LM
Luminous Intensity: 124000cd
Color Temperature: 1A 6500K / 3D 5000K
Switch Type: Side Clicky
Feature: Anti-Roll Rugged Design,Cooling Slot of High Efficiency,Lanyard,Lightweight,Pocket Clip,Power Indicator
Function: Camping,EDC,Hiking,Household Use,Night Riding,Walking
Battery Type: 18650,26650
Battery Quantity: 1 x 18650 / 26650 battery (not included)
Mode: 7 (Turbo - High - Mid1 - Mid2 - Low - Strobe - SOS)
Rechargeable: Yes
Waterproof Standard: IPX-7 Standard Waterproof (Underwater 1m)
CW link : http://www.gearbest.com/led-flashlights/pp_555779.html
NW link : http://www.gearbest.com/led-flashlights/pp_555780.html
Comment if you like to be part of the groupbuy . Groupbuy price is 37.99$ .
Groupbuy will be closed 15th of December , that time coupon will be sent and stock will be available coupon and stock now available .
