Utorch UT02 LED Flashlight - 1300Lm Cree XHP35 HI 2A Quick Charge
Groupbuy here : Click!
Overview :
Brand: Utorch
Model: UT02
Lamp Beads: Cree XHP35 HI
Luminous Flux: 1300LM
Luminous Intensity: 124000cd
Color Temperature: 1A 6500K / 3D 5000K
Feature: Anti-Roll Rugged Design,Cooling Slot of High Efficiency,Lanyard,Lightweight,Low-voltage Warning,Pocket Clip,Power Indicator,Tail Stand
Function: Camping,EDC,Hiking,Household Use,Night Riding,Walking
Switch Type: Side Clicky
Mode: 7 (Turbo - High - Mid1 - Mid2 - Low - Strobe - SOS)
Battery Type: 18650,26650
Battery Quantity: 1 x 18650 / 26650 battery (not included)
Rechargeable: Yes
Waterproof Standard: IPX-7 Standard Waterproof
Power Source: Battery
Working Voltage: 2.8-4.35V
Reflector: Aluminum Smooth Reflector
Lens: Toughened Ultra-clear Double Glass Lens with Anti-reflective Coating
Beam Distance: 601-700m
Impact Resistance: 1.5M
Flashlight Processing Technology: Aerospace Grade Aluminum Body with Anti Scratching Type III Hard Anodization
Available Light Color: Cool White,Neutral White
Available color: Black
Product weight: 0.306 kg
Package weight: 0.470 kg
Product size (L x W x H): 14.80 x 5.90 x 5.90 cm / 5.83 x 2.32 x 2.32 inches
Package size (L x W x H): 24.00 x 9.50 x 9.50 cm / 9.45 x 3.74 x 3.74 inches
First Look :
Package Contents:
1 x Utorch UT02 LED Flashlight
1 x 18650 Battery Holder
1 X USB Cable
1 X Lanyard
1 x O-ring
1 x English Manual
Some more pictures :
Flashlight has a nice , kind of matte anodization :
UT02 length : 14.80cm
Utorch logo close-up :
Closer look to the e-switch :
Back side , with USB port :
And a closer (over-exposed) of USB port :
Very nice Knurling :
Square , Anodized threads :
And tailcap side :
Reflector :
Reflector is made from aluminum , and it has zero imperfections :
Parts & Disassembly :
Left to right : UT02 head , Battery Tube , 26650 battery , 18650 battery , Tailcap
Driver side : Double springs , gold plated
Tailcap : We have double springs here too , and springs are soldered on a pcb that makes contact directly with the battery tube
I think most long 26650 batteries fit (sorry , i don’t have longer than Basens) :
Bezel removed (no glue
) . Reflector is threaded , and glass is AR coated :
Led is on DTP mcpcb (28mm ?) :
How it works (&modes) :
From off —> one short click turns the light on at the lowest level.
From off —> a long click turns the light on at the last used level (low mode does not count).
When the light is on —> a double click gives you strobe mode.
When the light is on —> a single click when the light is on advances in the next mode (low-medium-hi-turbo (if you are in the constant output mode) , strobe-SOS-“breath flash” if you are in the flashing mode).
Slightly longer click turns off the flashlight .
There is a shortcut for breath flash: from off make 3 double click.
When the light is on breath flash, a single click will activate the SOS, a double click will activate the last used mode.
In breath flash mode, the led under the switch will slowly turn on and off .
Measurements :
Using… Liitokala Lii 26650 battery
Lumens on highest setting (high mode) : Coming soon…
Intensity : 84kcd
Tailcap measurements (amp draw) :
Standby current (parasitic drain) : 0.007mA
- Low – 109.7mA
- Medium1 – 0.30A
- Medium2 – 0.60A
- High – 1.08A
- Turbo – 2.60A
USB charging :
When you connect the micro-usb indiactor turns red , and blue when battery is full .
Charge current is 1.95 A . (Approx 3 hours for a 5000mAh cells) .
Beamshots :
Coming soon…
