Smoother and nicer beam on the first heads with the original assembly.
Now there’s a bit more throw and artifacts due to the distance between the dome and optics when compared on a white wall. But that’s not an issue on normal use.
It’s probably because your picture file size is too large.
Try reducing the dimensions of the picture to about 640 x 480. That should reduce the file size to about 50 or 100 kB
no just email directly.
not a claim/incident in your account, email with “faulty Astrolux S41S” as title and mention ordernr in body, then pics should be easy to attach (mine were 5MB total I think)
The size doesn’t matter, but it’s damn picky with which browser you use.
I had no luck with any browser (including Chrome) from iOS, but Firefox from Windows 7 worked. Go figure…
I Agree. I compared the beams of my old and repaired S41S head with the replacement improved one from Banggood.
The repair was that I sanded a small slice off the underside of the optic so that the optic sits on the same height as before relative to the (newly reflowed) leds but now without damaging them. The beam profile looks like the beam how I received the S41S first.
The replacement head, as modified by Banggood, has the optic elevated a bit to prevent cutting the leds.
First the repaired head, next the replacement head, both heads have N. 219B V1 leds:
Clear to me is that the beam from the repaired head is how the optic is meant to project, and that the beam from the replacement head shows the led a bit out of focus (but it is still not a bad beam profile IMO).
So as already feared, the ideal focal plane of this optic is with the underside squeezed into the led (or else, filed down a bit works as well)
To complete the head that I repaired, I would need the tailcap plus battery tube. I hoped that tail-section+18350 battery tube was offered but it seems not.
So I placed my order on November 18. Got it today and all seems good. First thing I tried when I opened my package was unscrew the bezel. It came off. Then I popped in a protected 18350 and everything is great.
