Any time you unscrew the lens bezel you have to hold down the lens to make sure it doesn’t turn.
Also, the designer, George, has mentioned that sometimes a light will make a small noise. You can usually fix it by reheating the solder joints on certain components.
So i can confirm there will never be HI Cri or nichia version.
I talked with Georg the lamp designer and that was his answer.
I have one question the dqg Tiny 26650 v3 Will it be with the Nichia leds?
Greetings from Poland
George
19 April
Hi,
thanks a lot. due to the optics not so fit to the NIchia led, so, there will be no nichia version at current.
George
Yes, that is where I got my answer above, George on the other DQG thread. He said the box label was partly generic which is why it shows options that were never going to happen.
Prices have increased for 2018. There is nothing much i can do here. If you feel that it is on the high side, I recommend guys to seek for other newer models from other brands (e.g EMISAR D4 ).
