[quote=rizky_p]
hi Lexel are you doing another TA driver batch?
btw. BG moved the shipping date again this time August 31 2017.
[quote=Lexel]
I think for the size a 3 cell one with 12 Emitters would be good
I have updated the MF01 TA 2S board as there was a missing ground on switch pad
it is now confirmed it fits the light physically and works if switch ground was taken from another pad
TA 4. batch is about half of the possible drivers sold, so you can have drivers
Just canceled my Nichia version and tried to order the Cree version, should have read here first. Still a toss up on which version I want, more throw or better tint, though I’m not a tint snob. Maybe I can decide before Sept. 6.
I was able to check Lexels review and the battery carrier is 2S2p. So it’s 6 volts (8.4v). With his 30Q cells he measured 15.7 amps on Turbo. This equates to 7.85 amps per battery.
I also found HKJ’s test on the 26f. It will do more than 5.2 amps. He tested it at 7 amps, but the voltage sags pretty low.
So the 26f is not the best choice for such an extreme performance light. IDK what would happen if you tried to go turbo. It might be a reduced output turbo or it might not go into turbo at all. I don’t have enough experience to say what would actually happen. Maybe someone who knows more can speak up.
Thank you again for answering and confirming my suspicions. I have also seen these comparisons of 18650 rechargeable batteries from danish lygte-info.dk. I wonder how the flashlight will behave after step down how many lumens will it be?
