How does the Niwalker Vostro compare to the MF-02 in throw? I have the BK-FA09S
Here is info on the newest Niwalker light.
you are not up to date Jason
I rarely am up to date. Lol
bump
Will there be less current flow with the thermal paste left on ?
current will be same, but the voltage drop over those 3 loose screws will be higher
Thank you lexel
Is this GB still going on? Please put me down for 1 if the GB still on. Thank you.
Got my NW the other day. Works as it should, so far so good.
My cw the bezel was glued, on my nw it is not. Glad they made that change, or somebody forgot, whatever the case may be.
I do think one of them will end up with a 50.2 or maybe 70.2 eventually.
My cw the bezel was glued, on my nw it is not. Glad they made that change, or somebody forgot, whatever the case may be.I do think one of them will end up with a 50.2 or maybe 70.2 eventually.
I hope you thought on my MF02 BLF driver will provide a lot more amps than the stock driver
Lexel, what is the performance figures with your driver using a E23C 35 , i see the std driver lifted from 450 to 535 Kcd with the E2 3C
Dave
The LED is already driven pretty hard, I would not go higher with current, the BLF GT uses as well only 2.5A
The main advantage is the great UI
I noticed that an Aliexpress store is offering just the head of the Mateminco MT35 for sale. Full unit is $107. Just the head is $75. Interesting.
Mine came in today, it had thermal paste under driver retaining ring, wiped it off and threw a fresh set of 30Q’s in carrier and it works just fine. Throw is quite impressive! My second throwiest lamp is Astrolux C8. The MF02 destroys it! I also tightened all screws just to be sure… BTW, this carrier works with flattop 30Q’s also. I have a set of buttontops coming on a slow boat just in case.
I don't think it is a fair competition. LOL!
…Throw is quite impressive! My second throwiest lamp is Astrolux C8. The MF02 destroys it! …
I know! I have a stock Convoy L6 also, it beats MF02 in lumens and overall light, but of course, not in throw… I noticed that light flickers just a little bit on the lowest mode but not on any other mode, should i be worried?
My NW flashlight arrived today too. Had not opened it jet.
Edit: driver is fixed with Torx-screws. I have 2 removed and one damaged. could not get it out. :person_facepalming:
But now I see no heatpaste only loctite on the screws.
I have the Mateminco version from Alie. Cannot imagine the MF02 outperforming this version. I will do some tests tonight or tomorrow.
My NW version arrived too. I had several problems with our customs department and new Electronic system in our country, but after four days of phone calls and two hours on customs department I got it. Banggood very possitively surrprised me, because they put on the box price only 28,39 USD
But, did somebody measured how much less the voltage is, when the thermal paste is or isn’t between driver and batteries? According to my opinion, the contact is also made by a screws and when they are tight well, there should not be any loss of voltage . Or not? Because I tried to unscrew the screws with my cheap screwdriver, but I destroyed it, screws are tight very well. But small amout of thermal paste is visible on driver onder the ring so, there is any probably. But, if it’s working hands in pocket, or not? The throw is impressive after all.
