interested
Weird, when I asked to change my led to NW about a week ago after the mix up, I was told Blue finish was no longer available (which was what I’d ordered) in NW. Yet people are still ordering them lol.
Shame, was going to be my first coloured light other than black or grey!
Next to the head?
like this Fenix?
Fenix LD15R flashlight is a compact and handy right-angle flashlight with dual light sources: white and red lights. Powered by one 16340 rechargeable Li-ion battery, it is also compatible with a cold-resistant CR123A battery. The large pushbutton switch located on the top of the light makes for easy operation, it delivers a max output of 500 lumens and a max beam distance of 85 meters. Featuring four white and three red light output levels, plus Micro USB charging, battery level indication, two-…
Next to the head?
like this Fenix?
GearVita New Arrival: $6.99 Yeelight YLYD09YL Night Light - Photosensitive Sensor, Plug and Play, Ultra-low Power Consumption - #3 by cathy
I see several issues with that one.
First, they say the clip does not rotate. It always has to be opposite the emitter. It looks like the switch bezel can be loosened and the clip rotated. So maybe that is okay.
Second, it still has press and hold for on/off. Not what I want, but okay I guess.
Third, it uses a TIR lens. I want reflector. I have extra reflectors that might fit it, but the red leds are an issue. I would not be able to tell if they were on or not and I could accidentally run down my battery. I might be able to remove the LEDs entirely, but I’m not sure if the MCU would switch into sleep mode. I may still run the batteries down prematurely.
Fourth, the charge rate is a bit low at 0.66A. I could probably live with it, though.
For $50 -$60 it is not worth the risk of trying to mod it. I’ll have to keep looking. Thanks for the link, though.
TIR mod done by X1R owner.
Thanx Freeme. I just placed a Pre-Order.
Code.please.
Got message that is is shipped!
Preorder the NW blue one, thanks freeme.
Code please and thanks
just got my notification of shipping as well!
Interested.
Interested
All replied.
interested.
Ordered NW Black. Thanks Freeme!
Interested
Gracias
79mm with 18650 tube?
No, an 18650 battery is roughly 65mm long, so that is obviously not correct. They list the X1R as 79mm because it is an 18350 light.
The 18650 battery tube is an extra piece. If you install it, the length will be closer to 110mm.
Code
Please
