Enogear sent me this light as a gift for helping out with their first giveaway. So it wasn't meant to become a full review anyhow, so I will just do a short show and tell.
See their sales page: http://www.enogear.com/pd.jsp?id=81#_pp=0_455_5
Looks like Enogear turned into Fireflies?
Here is the new link:
https://www.ff-light.com/index.php?route=product/product&path=63&product_id=71
It's 19,90 USD,
Includes no strap, just a clip and a clamp for adding a strap. Packed inside a plastic case and bubble wrap.
Ui:
Lo-med-hi
Memory:
No... But if you turn it off within the first 3 to-5 seconds it will go to no next mode next time you turn it on.
Driver: 13.8mm
Amps on eneloop:
- Low= 0.15A,
- Medium= 0,6A
- High= 1.8A
Lumens: measured with home-built integrating sphere, calibrated with Convoy S2+ from Jozz
- Low= 7 lumens
- Medium= 39 lumens
- High= 124 lumens
No moon ;)
No blinkies :)
Mode spacing:
- 8%
- 30%
- 100%
Turbo timer?
Running a test now, and it doesnt have a turbo timer nor thermal regulation.
At start : ceiling bounce of 220lux
After 7 minutes it has a total of 180lux
I looked at the lux meter on and off, and the output declined slowly.
So it sagged about 20% in 7 minutes. (no cooling)
Driver:
14mm (13.8mm)
PWM:
- Yes, present and noticeable when moving the light quickly at Low and Med..
- Not present at High.
The size
- Length: 80mm
- Width: 19mm
LED:
- NW XPG2
Reflector:
- Nope, it's TIR, 45 degrees
Some pictures
Threads.
Good and not sharp
LED:
NW XPG2
Driver;
Inside Spring near tailcap
