Well it’s arrived! Thanks to Judy at flashlight-torch.com and DHL.
Firstly sorry but main camera bat expired other camera works so duff pics at the moment, anyway bright sun here…
First impressions, Very well made, great finish and no blemishes. a nice black in colour. It is head heavy but not overly.
Threads smooth.
For those interested Panasonic protected NCR-A-B won’t fit (will upload the photos later). Unprotected Bs fit fine and work OK so far.
The manual is all Chinese, so no help.
The tail switch is smooth in operation, once operated you are in standby, wish there were some form of indication that you are in standby, (revision for FF5?) I will add a LED at some time in the future.
Rightttt press side switch……. Ohhh smooth… oooo light…ramps nicely from cold (not checked with watch) but a few seconds later and hmm better get the sunglasses on. Press side switch again and the mode changes to low. From cold it takes about 5 seconds to get to SRK clone level. Not really have the hang of things yet, but after it warms up a long press gets it to turbo. Once warm switching on is quick just enough time for your eyes to adjust.
Going to be interesting when it’s dark.
more impressions later
Bit more! Afraid I’m a DH there is an indicator when it is on standby….the tail cap button glows, in my defence not that bright (good) but in sunny daylight at least I can’t see it….
Talking about the tailcap there are two good sized holes which should not interfere with tailstanding for a lanyard (not supplied). Also still not able to get turbo with 100% certainty (wish the manual had English) could be a rather large consumption of Guinness and Magners did not help matters as well.
Camera still not working so no beamshots tonight sorry.
Impressions of the beam are that it is more focused on throw than the FF3 Brighter than a TM26 on high and owns it on Turbo throw.
A few numbers, not definitive only as a comparison, ceiling bounce test
………………………………… Low…….High…………Turbo
SRK clone 2xl2t61lt6……………16………144
TM26 ……………………………………….143………….279……………………………….
FF4………………………………………….337………….500
More to follow
Answer to some questions as to the cells…. they are in series
Some pics most were a disaster will have to find a place with little veg in the foreground.
Not quite dark but the 4 on high trees right at the back 300yds+
Tm26
Control just before the FF4
FF4 turbo
Did some testing, some figures seems to fit well while there seems to be an almighty anomaly sitting there…
Ok here goes (I believe my meter under reads between 4-5% checked against a known meter).
control TM26 (@ 10mtrs) 41.1kcd
FF4 ,40w,(@10mtrs) 221kcd
FF4 turbo……(@10mtrs) 327kcd
Ok an attempt of lumens measurement. Firstly again using the TM26 as a control the 40w measurement came out with a figure near 4900, 400 lumens more than I expected but the turbo figure was ridiculous at over 7300 lumens, so I am going to have to check things very carefully to see where I have gone wrong….
Also It’s only had a total of around an hour of use.
