Hey da, that BOSS1 is a classic, still is! Ok, it's a BIG classic, quad 26650's. I do still really like mine though.
2300 lumens out of a 16340? I don't think so, unless the 2 clicks means 2 secs... I think it has the simple UI people have been asking for in other threads:
1 click: 1000 lumens (probably 200)
2 clicks: 2300 lumens (probably 500)
2 more clicks: strobe
drop the strobe and it's simple enough.
It's a nice look'n light though, but chunky for sure.
I was looking for one at some point. Seemed cool but impossible to find. These days, everyone would probably see the size and start talking about SBT90.2
At first I though that might make a good host. Swap in a FET driver and a real 70.2, maybe 3 high drain cells and youād have an awesome thrower. Especially at the $29 price. Then I see itās all plastic. :weary: So no real ability to handle heat.
I found a cheap stepless dimming driver with built-in USB C for charging. I donāt know what it could be used for.
Some information from the product page:
Diameter: 28.5mm
PCB Thickness: FR4 1.6mm
Input Charging: Type C USB 5V 2A
For T6 U2 L2 XPL V3 LED: Output current: 2A-3A, Output voltage 3.7V
For XHP50 LED: Output current: 3A-5A, Output voltage 3V
Mode: 100% - Off
Long press switch turn to stepless dimming mode: In the current state, the brightness first decreases and then rises. When it reaches lowest or highest, it will flash twice and wait for 1 second to continue to increase or decrease.
Charging: battery power 5ā95 red light on, fully charged green light on
Discharging: battery power 100ā50 green light on
battery power under 50% red light on
It's a fairly common look of a driver - USB-C on one side, rt. angle board mount switch on the other, with a SMD dual color LED. The size of 28.5 mm is a little odd, being on the large side. So with the size and host dependent switch and USB-C, it's practicality is extremely limited for most modding, specially with limited machining resources/talents.
I'd think this driver was a mistake, or a production batch for a new light that didn't happen.
This is a flashlight/host thread, not a driver thread, but dunno where else you could post this - still an interesting find.
There have been many huge headlamps already, but I havenāt seen the uv panel yet.
And no, those big holes arenāt the holes to look through.
Link in the pic.
