I’ve got other projects I want to get on with so this is now for sale. $50 plus shipping.
I don’t know if the host has a name??? I bought it from Simon - good flashlight host for you
I stuck an xml t6 in it and ran it at 3 amps. I wasn’t all that impressed. I thought ‘I could’ve bought a light just like this, stock, and I wouldn’t have had to work on it myself’. So I planned a light BLF worthy.
My initial plans -
Custom pill
dedomed sst-50
9 amp driver
batteries I kinda have already
I made the pill before I realised I should take some pics. Not that you’ll have missed much, my work is not ideal. I started with 1” copper bar, cut it to length, drilled it from one end. Because of the shape of the drill bit I got in there with a dremel as well. I don’t have the gear to thread the bar so it will have to be a press fit which meant I needed to grind off the threads in the neck of the host. I wasn’t 100% sure how much space I was going to have and I knew it was going to be a tight fit so I pressed it into the neck before finishing the work I needed to do on it. It didn’t press in as far as I was planning which means the led sits a little high. Later, when I fitted the driver I found out it was a squeeze on that side as well.
Whilst doing all this work and looking at the stock pill it occurred to me that it resembles a C8 pill. I don’t know if it will fit, maybe someone that purchased this light and owns a C8 might be able to clarify. If it does fit then there are copper pills available from vesture-of-blood. That would’ve made it so much easier for me.
So being a bit backwards myself I made a rib for the led to mount to after pressing it in the neck :zipper_mouth_face:
In this next pic you can see I used too much solder :~
This is the driver
I had to add a spacer between the circuit board and the contact board otherwise the driver gets squished when the battery tube screws in.
The contacts on either side of the led is actually the remains of an sst-90. I don’t know why I was hanging on to a dead led but I found a use for it. It was already dedomed, I flipped it and cut the + and - contacts so I was left with the centre pad. I then cut it in half and use one for each side.
Just don’t laugh at my soldering. I know I’m rubbish :_(
The contact board gets clamped when the battery tube screws in. The thickness of the board plus the spacer I put in means I can’t screw the battery tube all the way. The head doesn’t go all the way on either, I’ll get a pic of that later.
That was as many pics as I got before I did some test runs. I knew the current was too much but I was honestly expecting it to survive. I did a quick on/off. The tint looked really blue. I wasn’t sure why at first so forged on. This time I turned it on and quickly tried to move to a lower mode. The instant it turned on it was the tint I was expecting then moved into the blue that I saw before. I did manage to click to another mode but either the led or the driver died. I don’t know which because the first took out the second. :_( It really cheesed me off so I left it for a day. Of course, I stewed on it and had to fix it up so fitted another 9 amp driver this time powering an sst-90.
I’m happier with it now but it needs a tweak here and there. I might get beamshots this weekend.
