ASTROLUX EC03
USB-C 18650/ 18350 Flashlight
Group Buy Price: $35.99 $39.56
Freeme's Coupon: Request in this thread
Brightness: 6700lm (XHP50.2) / 5700lm (SST40)
Color Temperature: 5000-6500k (depending on model)
Body color: Black / Brown / Green
Battery Type: 1* 21700/ 18650
Can't wait for our reply??
FLASH SALE Price: $37.99
Coupon: N/A
Valid from : December 3 to December 15
Price: $8.95 / Coupon: BG1PSS
Express Your Interest Below
Try not to PM me
Fire starter with 40T
Specifications:
- Emitter: 3* CREE XHP50.2 (3V) LED on a copper DTP MCPCB
- Max. Output: ~6700 lm
- Color Temperature: 6500K
- Throw: 303 m
- Firmware: The EC03 uses free software called Andúril, distributed under the terms of the GPL v3. Code is available from http://tiny.cc/TKAnduril
- Driver: FET+1 driver. Low parasitic drain while OFF
- Body: Aluminum with HA III anodizing
- Battery: 1x premium 21700 cells. Unprotected cells are recommended.
- Charging: Integrated charger via USB-C
- Switch: Electronic side switch
- Lens: High transmittance glass
- Ingress rating: Equivalent to IPX8
- Weight: Approximately 175 g without cells
- Size: 48.5 mm Ø head x 126 mm length.
User interfaces:
[1] By default the EC03 is set to use SMOOTH RAMPING. Instant access to TURBO mode is also provided.
[2] A more conventional STEPPED RAMPING UI is available if you like discrete modes level. You can choose how many steps you want.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets. To exit this mode, physically disconnect power
[4] MUGGLE mode uses a reduced output.
[5] It has an electronic LOCKOUT for safety, but acts also as momentary low light.
Other functions: Battery check, sunset, beacon, tactical strobe, party strobe, bike flasher, candlelight, lightning storm
Package Included:
- 1 x Astrolux EC03 Flashlight
- 1 x 18650 to 21700 battery tube
- 1 x Type-C USB cable
- 2 x Spare waterproof o-rings
- 1 x Lanyard
- 1 x User manual
