Does anyone have an suggestions for a good 26650 that would let me get the full potential out of this light but still be somewhat affordable? My wallet is running low and the fw3a group buy is coming up soon so i don’t wanna spend too much. I guess I could use 18650s but I don’t have a bunch of spares so I’d probably have to buy a couple more of those anyways.
Interested in NW
There aren’t a lot of good 26650’s around.
I would (and probably will, only have 2 26650’s) get these:
Interested in NW code please.
Are there any specs of this light concerning dimensions? How do the dimensions compare to a single cell L6?
This is what it says on the listing:
Dimensions: 170mm*69.5mm*34.5 (length*head diameter*body diameter)
Thanx, must have missed out that part
Johm’s suggestion is a good one but you have to Buy Two.
If you live in the States,these Two dealers are selling the same cell.
Orbtronics is OUT of stock but Mt. Electronics have it and you can get One.
It is known to be the best 26650,I can not recall the cell[I am getting old],iirc PLB-55.
Orbtronic and Shockli re wrap the cell. Great run time and plenty of amps.
Shockli version:
Orbtronic version
Has anyone tried one of these? Saw it on one of the deals threads and I know I’ve seen people talk about this brand’s chargers but idk anything about their batteries and the price seems a bit too good to be true.
Liitokala is ok but Shockli/Orbtronic are better run time and amp draw.Plus Liitokala have been know to be counterfeited,there are threads on that also.
Your answers are on here: HKJ Comparator.
https://lygte-info.dk/review/batteries2012/Common26650comparator.php
Here is the cell that is used in it. PLB55
Thanks for all your help
Interested in NW, thanks
Interested in CW.
ANYONE??
The sentence below came from the bottom of the Second paragraph from “ADVANCED OPERATION” in the User manual.
“A continuous press exits the setup menu completely. Four blinks indicate that the setup is completed.”
Does that mean to CONTINUE and press and hold UNTIL 4 blinks OR press/hold for several seconds then RELEASE and wait for Four blinks?
USER MANUAL LINK BELOW:
http://img.banggood.com/file/products/20190129202400FT03usermanualdraft04withadvancedsettings.docx
Can not get it work. every time I try to copy/paste the manual it reverts back to my downloads on my computer,whether I use Pete7874 original link or one from banggood.
Maybe it will OPEN for you!
THANKS
Interested in NW
Interested. Can I have coupon for $ 27,99 ?
Ok, I know exactly what they are talking about (well I should know... I, of course, wrote the code )
I added this feature as a quick shortcut method to bail out of setup/config mode. So for example if you completed what you wanted to do and don't want to wait for the rest of the setup/config options to blink there way through, simply press&hold down til you see the 4 blinks, then take your time - release the switch anytime you want. The press&hold acts as a quick bail out - it won't have any effect on setup/config settings.
Again, you don't have to do this -- it's just a shortcut to save you time. I use it frequently when switching between ramping and mode sets, for example, because it's the first setup option and I want to bail after changing it.
Oh - the link works fine for me. It downloads a "docx" file which is in Microsoft WORD format. Not a good idea, a PDF would be safer and more universally accepted. It's also easy to convert the docx file to a PDF... Weird.
Thanks,so when I am DONE w/ my disabling TURBO which is setting #3 and clicks #1, then I just hold and press until 4 blinks, release switch and the process is complete?
If I order both a CV and a NW will they be sent together? I have to pay 25% tax and 24 dollars tax handling fee!
Very Interested with this. Please PM m with code.
