Wrapped so it wouldn’t rattle in my Zebra Light SC700d…. yeah I can’t believe I fell for the Zebra Light BS myself! Nice light, not $120 dollars nice, I don’t care what the UI does or don’t do… rather have Narsil in it.
I only used my 30T/40T for a few minutes to test both lumens and candela. I plan to stick with my 50E as it provided the same performance. I’m going to retest the lumens with the 50E and see if I get the same readings, hopefully indicating no damage was done with possible excess heat?
Depends on the light and who is using it. I use Nothing but turbo on the trail. If the light has a step down I step back up until too hot too hold. Most of my modded lights[only ones I use on the trail] either have a programmable[default 20 minutes] step down or thermal step down.
This was 20 minutes later[when I got home] after using the TN42vn 90 for extended summer time turbo runs! :sunglasses:
So what would happen if you put in a Sony VTC5A Or Molicel P26A,Both capable of at least 25A continuous and probably 30A???
You would think and Hope that Astrolux has thought ALL this through and tested these various high drains.
The problem is, if they did NOT, and the light fails,getting a refund for a $30 light that came from China would be difficult, costly[sending it back] and not worth it.
I am going to go out on a limb and say that any battery will be fine[!!!] and NOT worry about what battery goes in here,I will be the guinea pig! If it fails,I guess I am out $30!
My hometown dealer Liionwholesale is the Only USA authorized distributor of Molicel.
He has the:
Molicel/NPE INR-18650-P26A - The best high amp 18650 battery cell
Molicel/NPE INR-20700A - Great high power 20700 battery cell at low price
Molicel/NPE INR-21700-P42A - The best 21700 battery cell that offers cutting edge high power and high capacity
I made a new tailcap current measuring jig. Old one was hurting my hand to press into the battery.
14ga wire, a brass washer, a plastic thingy I had lying around, a spring, and a brass button.
Thanks and you have to be right according to physics . I’m just trying to understand the magnitude of current that actually passes through the emitter. Is it 99.9, 99, or 90%?
At the numbers we’ve seen, I was doubtful that the SST-40’s would survive. Current doesn’t disappear, of course, but it does take alternate paths, where available. I can accept that driver current losses are perhaps so minimal as to be irrelevant, though, if that’s the case.
It’s hard to understand how anyone here could be measuring more than ~9.2A without burning the bond wires within a minute or two. koef3 had the test emitter on a fan-cooled heat sink, so in an actual flashlight the temperature should rise further and faster. However, we don’t actually know the current with the tail cap installed. (nkresho’s rig surely comes close)
Still, as pointed out by others, no one here has burned an emitter… yet. Maybe it’s inevitable?
Yes, koef3’s tests were on an earlier run of emitters, but could they substantially improve the bond wire capacity without a redesign? If improvements were made, the product page and datasheet would surely show higher limits. They continue to sell these as 5A emitters.
As noted by koef3 in the test, the SST-40-W datasheet is still labelled “Preliminary” and is dated 2015, so Luminous doesn’t care so much about product information. As others have stated, there’s still no part numbers for temps below 6500K in the datasheet. As nothing’s changed in the document, the datasheet still lists 5000mA as the maximum.
After APPLYING my quote,“Solitude breeds contemplation which creates clarity.”
It is quite apparent to me at this point in the “FT03” BLF testing and speculation history, that it is a NO BRAINER in terms of what battery to use.
That battery would be the OEM PLB-55A cell. The re wrapped Orbtronic/Shockli 26650 20A 5500mAh cell. The KP version is way over priced.
1.Why would one want to use the 30T/40T or P42A when several gentlemen[use that term loosely] have tested and shown that there is NO increase in output when using them.Actually can DECREASE the output.,
When Kawiboy tested: “When I tested the 30T it actually lost out put from too much current 9-9.4 seems to be the max before output drops from over current on my FT03.”
2.There is also belief that these high current batteries can/may fry the emitter.
It could not be more clear to me at this point. Maybe when Tom E. and some others get their lights, they may get different results. But I DOUBT it.
Tomorrow morning I take that vigorous 0.9 mile hike to Liionwholesale and exchange my 2 X Molicel P42A . NEVER used in a light, Only a capacity test. Jon will graciously refund me as he always has!
Finally got some movement on one of the FT03's - it landed at JFK. Heh - I don't really mind burning out a SST-40 in the name of science. So I'll probably add bypasses, maybe up the AWG of the LED wires, measure amps, and try a 30T or P42A.
That nkresho rig you got there is an outstanding job!!
It's been bugging me. If the NW passes, I should try an older CW.
