Okay, Lexel did not want to say too much about the driver except that it is “3 channel” and uses a “TP5100 Charging circuit”.
We can probably assume Channel 1 is a single 7135 because it almost always is. It gives good control over the moonlight modes. Channel 3 would be the FET. Channel 2 is unknown, probably 7 or 8 chips as that’s common.
We probably won’t know for sure until we can see the driver.
Hello. I apologize for possible duplication of the question. I couldn’t find any information about the characteristics of the lenses. Can you specify the beam scattering angles? I personally like optics of Emisar d18 with it`s ultra wide angle. Besides, is it so difficult to release the MF01 Mini version with a combination of ST20 at 4000K and 6500K for color temperature correction?
yeah This is a very big difference in temps… I would go with the XP-L HI option to… I am not very impressed about SST 20 temps… on my E07…
in fact… I regret not getting the XP-L HI option with 4000 with the Fireflies E07…
Copper plating would be nice, but I really doubt they’d want to go to the effort of plating(machining-zincating-flash copper plating-copper plating), even though it would actually be less expensive.
Yes, a fancy thing, but there is no real sense IMHO, pure wow effect. the copper is good at conducting heat (btw is this pure metal or alloy) but useless if you do not have a point that utilizes this heat. btw the specific heat capacity of aluminium alloy is about twice more than pure copper.
